Why is there oil?
Old Jul 22, 2007 | 11:33 PM
eG6 driver3's Avatar
Default Why is there oil?
Ok, I already changed the valve cover gasket and the spark plug rings. And I don't understand why is there still oil going threw the spark plug area? Not a lot just a little bit.
Any suggestion or answers to why is this happening?
bmoua's Avatar
could be cam seals...where is the leaking coming from?
Old Jul 22, 2007 | 11:37 PM
It's leaking to the spark plug area. Just a little bit.
Old Jul 22, 2007 | 11:38 PM
93stockej1's Avatar
there are seals on the bottom of the spark plug tubes as well. its in an article here, should be easy to find in a search. but i would have to say the bottom o rings would be my guess
Old Jul 23, 2007 | 03:05 AM
nfrguambomb's Avatar
more input please.
i have the same exact problem.
Old Jul 23, 2007 | 06:08 AM
ic's Avatar
ic
Default Re: (nfrguambomb)
on certain engines, the spark plug tubes are two piece. The lower half is cast into the head, and the upper half is cast into the rocker assembly.
qhiggy
10
Mar 3, 2015 08:49 PM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
VTEC_Du_Ma_Mai
Sep 5, 2008 01:41 PM
BB6racer
Jan 18, 2006 05:20 PM
gixxer6
Oct 29, 2002 01:10 PM
