civic eg with gsr engine white smoke
Old Jul 22, 2007 | 09:18 PM
newtype_civic's Avatar
Default civic eg with gsr engine white smoke
i need help i got gsr swap on my eg after i did the swap the car was runnin perfect until i decided to put a stage 2 cams and replase head gasket and put hondata entake gasket new valve seals valsve spring and retainers with stock bottom end after putting everything together i test drive the car and there was a white smoke comin out of my exhaust on a high rpm what could be the possible problem do i have to get it tune?
Old Jul 22, 2007 | 09:19 PM
sageuvagony's Avatar
Default Re: civic eg with gsr engine white smoke (newtype_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newtype_civic &raquo;</TD></TR><TR><TD CLASS="quote">i need help i got gsr swap on my eg after i did the swap the car was runnin perfect until i decided to put a stage 2 cams and replase head gasket and put hondata entake gasket new valve seals valsve spring and retainers with stock bottom end after putting everything together i test drive the car and there was a white smoke comin out of my exhaust on a high rpm what could be the possible problem do i have to get it tune?</TD></TR></TABLE>
uhh... love the punctuation there lol. White smoke = coolant. The headgasket wasn't installed correctly or head wasn't torqued/sequences correctly.
Old Jul 22, 2007 | 09:35 PM
Default Re: civic eg with gsr engine white smoke (sageuvagony)
that maybe right cause i use a arp headstuds and i use torque settings from the repair manual.should i retorque the head or replace it with a new head gasket? i have a cometic head gasket installed right now
Old Jul 22, 2007 | 09:40 PM
slowcivic2k's Avatar
The torque for ARP's is higher than factory, so you will need to base your torque off the yellow card that came with them.
If it blew your gonna need to replace it, because it has a wrinkle/weak spot.
Clash0901
12
Jun 6, 2010 01:36 PM
caliEG2dr
May 15, 2010 12:44 AM
SleepyHatchZ6
Oct 28, 2008 07:54 PM
eg6civic1538
Apr 22, 2007 06:36 PM
III50z
Oct 11, 2006 04:27 AM
