replacement filter for comptech intake.
so i measured my foam UNI filter that came with the comptech intake to try and track down a k&n replacement, it was 4.25 inches id inlet and 8 3/4 inches long. Tried to crossreference that size on k&n's website but had not luck.
I was wondering if anyone had a suggestion as to what filter to use to replace the foam uni filter. I really dont care for it, i really question how well it filters. I know that the foam filters flow better than other filters but my car is a dd and to me it is more important to have good filtration and sacrafice some flow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eva01 »</TD></TR><TR><TD CLASS="quote">I use the Spoon filter. It fits fine...and was given to me for free FTMFW!
*sigh* lucky bastard
</TD></TR></TABLE>*sigh* lucky bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_gs-r »</TD></TR><TR><TD CLASS="quote">so i measured my foam UNI filter that came with the comptech intake to try and track down a k&n replacement, it was 4.25 inches id inlet and 8 3/4 inches long. Tried to crossreference that size on k&n's website but had not luck.
i would also like to know what others use. i tried a couple different k&n filters to fit on my ice box but had no luck. i searched and tried the k&n filters that other icebox owners used but there's was never one that fit perfectly without me having to modify it. i ended up just ordering the foam filter cleaner through comptech and i cleaned it and it looks brand new. only problem is i have to clean it quite often.
well the filters posted may work with the oem rubber tube but i am using the complete comptech setup (intake arm, velocity stack, icebox). The k&n that was linked earlier has a coupler with a 30 or 45 degree bend on it.
There isnt much info on this out there. I may end up tkaing it to a local k&n dealer and see if they can match it up. I thought for sure someone would have replaced the carppy foam uni filter.
The bend is normal.
Thats what a stock filter looks like.
It should work fine with just an icebox, I dont know about the comptech intake arm.
I have a E2427 and it works great.
I also have a RU-2820 that I modified to work.
If you are looking for something that is similarly sized to the stock filter, but doesnt have the bend, then the 2820 is really close.
Takumi Fujiwara
Oct 31, 2005 10:02 AM
Honda.F1
May 15, 2004 03:27 PM
