Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
90k Maintenance...
Old Jul 22, 2007 | 03:53 PM
rushbuster70's Avatar
Default 90k Maintenance...
Anyone know what this includes...i'm just about to 90k so i'm just curious what type of things need to be done...
And before you blabber about looking in the owners manual I CAN'T...I ruptured my achilles and had surgery last week and so I cant even walk.So my cars just been sitting but I'm still curious what is included in the maintenance.Thanks
Old Jul 22, 2007 | 05:05 PM
awang's Avatar
Default Re: 90k Maintenance... (rushbuster70)
Replace engine oil and filter.
• Install engine & fuel system treatment.
• Replace oil pan drain plug washer.
• Inspect & adjust front & rear brakes.
• Lubricate chassis as necessary.
• Rotate tires.
• Inspect undercarriage for damage or leaks.
• Inspect tie rod ends and steering gear box.
• Inspect suspension components &
drive shaft boots.
• Inspect and top off fluid levels.
• Check horn and operation of lights.
• Check seat belt & other safety restraints.
• Check wiper operation & add new fluid.
• Inspect air filter.
• Pressure test coolant system & check connections.
• Inspect fuel lines & connections.
• Check and adjust parking brake.
• Inspect brake hoses and lines.
• Inspect ABS actuator.
• Inspect exhaust system.
• Adjust valves as required.
• Replace air cleaner element.
• Inspect and adjust drive belts.
• Transmission fluid service.
• Replace non platinum spark plugs (Plat. Addl)
• Inspect & adjust idle speed.
• Perform battery service.
• Road test vehicle.
• Brake flush.
• Transmission flush.
• Power steering flush.
• Cooling system flush.
• Engine oil flush.
• A/C pollen filter.
Modified by awang at 7:10 AM 7/23/2007
Old Jul 22, 2007 | 05:48 PM
thank you much...any opinions on it?is it worth doing it at the dealer?
Old Jul 22, 2007 | 06:08 PM
Boilermaker1's Avatar
Nothing is ever worth doing at the dealer. About a 1/4 of that stuff NEEDS to be done. The rest of it is some tech checking boxes.
Modified by Boilermaker1 at 10:56 PM 7/22/2007
Old Jul 22, 2007 | 07:19 PM
petty$rep's Avatar
Default Re: (Boilermaker1)
its all basic maintanence. i would never pay anyone to do something that i can easily do myself... unless i was super rich.
Old Jul 22, 2007 | 09:48 PM
thank you much...the only thing i plan doing at the dealer is the transmission flush because i've read about too many people have there trans go out.maybe the power steering too.cant do anything with a bummed foot
Old Jul 22, 2007 | 10:03 PM
awang's Avatar
Default Re: (rushbuster70)
i had the dealer do my AT flush. i read about doing it myself, and it seemed to be too of a job while i was taking my semester finals for college
Old Jul 23, 2007 | 05:42 AM
fventura03's Avatar
nice, thanks for that list.
Old Jul 23, 2007 | 01:50 PM
petty$rep's Avatar
Default Re: (fventura03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rushbuster70 &raquo;</TD></TR><TR><TD CLASS="quote">thank you much...the only thing i plan doing at the dealer is the transmission flush because i've read about too many people have there trans go out.maybe the power steering too.cant do anything with a bummed foot</TD></TR></TABLE>
auto or manual?
Old Jul 29, 2007 | 05:27 AM
hondacivic0909's Avatar
ok ur right except for the engine and fuel system treatment and the p.s flush im a tech at a honda dealership and honda does not recomend doing those items
Old Jul 30, 2007 | 10:54 AM
phootbag's Avatar
Default Re: (hondacivic0909)
These civics get spark plugs at 110k with the timing belt.
I work at a dealership. I make sure my customers always get what they pay for. My customers never get ripped off and always get my best ability.
I hate it when bad techs get employed. They ruin the perception that customers have of technicians and shops in general and make it hard for me to earn trust.
Old Jul 30, 2007 | 11:00 AM
awang's Avatar
Default Re: (phootbag)
i'm confident that honda's service men know what they're doing, but the prices they charge are often outrageously high
Old Jul 30, 2007 | 06:15 PM
s13_240sx_92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">Nothing is ever worth doing at the dealer. About a 1/4 of that stuff NEEDS to be done. The rest of it is some tech checking boxes.
Modified by Boilermaker1 at 10:56 PM 7/22/2007</TD></TR></TABLE>
^^^ this is true, these cars are easy to work on, if you have a few brain cells and a few tools its all DIY stuff. Any questions honda-tech is here to help.
Old Aug 6, 2007 | 09:26 AM
so i think i'm going to just get the 90k because i really just want my tranny and power steering flushed and its about 400 just for that and i called showcase and its just about 400 for the full 90k so i figured just to get the whole thing done...good idea???
Old Aug 6, 2007 | 02:58 PM
phootbag's Avatar
Honda has no service interval for power steering fluid replacment. A typical 90k on these cars is two fluids and three filters plus a comprehensive safety inspection. If you know how cars fail and wear out and you can change some filters and fluids, then you can do all this yourself.
Old Aug 6, 2007 | 07:17 PM
i wish man...i ruptured my achilles and cant do ish...
toyomatt84
Jul 31, 2009 08:47 PM
blaisepascal
Jan 2, 2005 10:01 PM
yazac
Aug 16, 2003 12:55 AM
uNF$@#!
Mar 1, 2003 08:10 PM
jokerstud
Dec 22, 2002 08:27 PM
