Need help!
Old Jul 22, 2007 | 11:18 AM
mortificationrock's Avatar
Default Need help!
Hey i was wondering if anyone knew what can cause someones idle to stay up as in around 2000rpm but if i press the accelerator quick it goes down !! I just changed throttle bodies and now it does that!! It didint use to do it. Could it be that i need to adjust my throttle cable? Thanx to everyone who inputs
Old Jul 22, 2007 | 11:37 AM
Anybody?
Old Jul 22, 2007 | 11:39 AM
Boost_V's Avatar
Default Re: (mortificationrock)
Well, if that's the only thing you changed, i'd take a look around that area. It seems logical that it would be that.
Old Jul 22, 2007 | 11:54 AM
Luserkid's Avatar
Default Re: (Boost_V)
Who changed the throttle body? you or a shop? If a shop take it back. Also what throttle body is it? Check the gasket.
Old Jul 22, 2007 | 11:56 AM
Syndacate's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Who changed the throttle body? you or a shop? If a shop take it back. Also what throttle body is it? Check the gasket. </TD></TR></TABLE>
Yeah, it sounds like the throttle body gasket tore and it's sucking air in through the leak (vacuum leak = high idle).
Either that or your butterfly's getting jammed.
EDIT:
If it's the original gasket, they usually tear when you pull it off, so replace with a new one and make sure you scrape all the old gasket off or try to find where it's leaking and use that "form-a-gasket" ****.
Old Jul 22, 2007 | 12:10 PM
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT:
If it's the original gasket, they usually tear when you pull it off, so replace with a new one and make sure you scrape all the old gasket off or try to find where it's leaking and use that "form-a-gasket" ****.</TD></TR></TABLE>Wel its not the gasket. Now we you reffer to the butterfly **** how can i fix cuz it seems to be that!! If i accelerate it stays in high rpm then i go press alittle in the throttle butterfly and it goes down
Old Jul 22, 2007 | 01:18 PM
TO THE TOP
Old Jul 22, 2007 | 01:49 PM
BUMP
Old Jul 22, 2007 | 01:51 PM
Libertariat's Avatar
Ek Forever y0!
If the gasket looks fine, at least play with the tps a little.
Bakersfieldgsr
Nov 12, 2007 03:34 PM
TheTealHatch
13
Oct 11, 2007 02:28 PM
Gsr.Turbo'd.Teg
May 7, 2007 03:59 PM
0260MOTORSPORTS
Dec 7, 2006 06:47 PM
rasta420
Mar 18, 2003 10:42 AM
