dizzy wiring / ckf bypass
i've read the faq's and i'm a lil confused. do i still have to convert over to an obd1 dizzy in an obd2b car if i do the ckf bypass. 00 civic w b16a running obd2b ecu. any suggestions?
Get a P30, and ignore the CKF, no need to "bypass it" its on the oil pump housing, and is not present on OBD1 engines.
If you run an OBD2 ECU, you will need that sensor plugged in, unless you went out and bought a new oil pump housing to hold the sensor, a new timing belt pulley with a reluctor wheel on it, and the sensor itself, then you'll be fine.
aw1234dude
Dec 15, 2004 06:32 PM
