Need advice on these guns.
I am currently looking for another gun to shoot clear out of. I already have a primer gun and a SATA 3000RP along with a SATA minijet. Looking on EBAY where I got my RP for a steal I ran across these. I have sprayed clear out of the Plus gun and really like how it shoots, however I didn't know how the others are. If anyone has any experience with any of these guns or any other gun please give me some input.
GTI
Plus(Friki Tiki)
Both are the same but I like both designs
Aces Wild
Modified by SneezinCD5 at 10:29 AM 7/22/2007
GTI
Plus(Friki Tiki)
Aces Wild
the gti's are good guns. i used to use the millenium but its a bit heavy so i have switched to spraying sata nr2000 for the past year or so. but if you get it for a good deal the gti's a great gun. but if you come across a nr2k for a good deal you should pick it up.
I personally have a 620g and it has been a great gun. But if you already have a Sata 3000 and a Minijet, I would just stick with those 2. 3000RP should be perfect for all of your base and clear shooting. No need to down grade.
not downgrading but the Plus guns lay the clear down much better than the Sata. I like my sata for base. I need a clear gun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 »</TD></TR><TR><TD CLASS="quote">not downgrading but the Plus guns lay the clear down much better than the Sata. I like my sata for base. I need a clear gun.</TD></TR></TABLE>
What clear are u spray.....We use both the 3000 and 4000....Plus the 3925fleet clear on the fleet side of the shop......Im going to be putting the fleet on my car cause it has more depth than any clear i have found so far
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigblockhatch »</TD></TR><TR><TD CLASS="quote">
What clear are u spray.....We use both the 3000 and 4000....Plus the 3925fleet clear on the fleet side of the shop......Im going to be putting the fleet on my car cause it has more depth than any clear i have found so far</TD></TR></TABLE>
At work we spray Nason and Dupont clear. On my own projects I use PPG DCU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPATIENT »</TD></TR><TR><TD CLASS="quote">the gti's are good guns. i used to use the millenium but its a bit heavy so i have switched to spraying sata nr2000 for the past year or so. but if you get it for a good deal the gti's a great gun. but if you come across a nr2k for a good deal you should pick it up.</TD></TR></TABLE>
I also base/ clear w/ NR2000's. I've cleared w/ a few different guns but I prefer the SATA's
Convert
Paint and Body
43
Sep 13, 2007 05:22 AM
STEV3-O
Northern California (Sales)
Sep 12, 2005 04:29 PM
