I screwed up! Putting back tranny... slave cylinder
Old Jul 21, 2007 | 01:34 PM
garyhgaryh's Avatar
Default I screwed up! Putting back tranny... slave cylinder
Ok, so I finally got the tranny in my Civic Vx. I put the pin back in the extension rod (remember the "bitch piin"? That rod). So I go in to see if I can shift through the gears.
I push the clutch in and it goes all the way to the floor! Shoot! I'm not suppose to touch the clutch pedal until I attach the slave cylinder to the tranny. I go to the engine compartment, push the shaft all the way back into the clutch cylinder, and attach it.
I go back into the car and the clutch has very little resistance.
Did I screw up anything??! If I did, what needs to be done?
Thanks,
Gary
Old Jul 21, 2007 | 01:38 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: I screwed up! Putting back tranny... slave cylinder (garyhgaryh)
You need to bleed the clutch. Your fine
Old Jul 21, 2007 | 03:00 PM
garyhgaryh's Avatar
Default Re: I screwed up! Putting back tranny... slave cylinder (5_Lug_B)
That's good to hear. If the shaft goes out of the cylinder, wouldn't I have destroyed the seal since the shaft has never gone that far? It'll tear up the seal right?
Gary
Old Jul 21, 2007 | 03:05 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5_Lug_B &raquo;</TD></TR><TR><TD CLASS="quote">You need to bleed the clutch. Your fine </TD></TR></TABLE>
Yeah, you just let air into the lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyhgaryh &raquo;</TD></TR><TR><TD CLASS="quote">That's good to hear. If the shaft goes out of the cylinder, wouldn't I have destroyed the seal since the shaft has never gone that far? It'll tear up the seal right?
Gary</TD></TR></TABLE>
It shouldn't tear up that seal - I've never seen that happen, anyways. I mean use ur eyes - attach the slave cylinder and see if it leaks when you clutch.
Though bleed it and it'll feel fine again.
blacklsvtec24
Apr 3, 2008 12:04 PM
hspoon
Nov 20, 2006 10:38 AM
omega2099
Aug 25, 2004 11:41 AM
k-man
Jul 24, 2003 07:04 AM
