what can i expect to run with my set up?
Old Jul 21, 2007 | 11:21 AM
danilorecinos's Avatar
Default what can i expect to run with my set up?
hey i got a 92 eg..its only going to have two front seats in it..i am haveing a ls vtec being built "ls bottom,b16a head"..with only the sleeves and the cams being the only things being stock on the motor..low comp pistons,rods,rings,valves,springs retainers,im also having a quaife lsd being put on it,and some 500 hp axles too..stock intake manifold and throttle body..im looking for my tuner to squeeze out about 420-430 hp on this set up with pump gas on a sc61 turbo..what do you guys think i can run with slicks?i consider myself a good driver i just need to get used to the car when it comes out..
mods
head
b16a head not ported
stock b16 cams
valves,retainers,springs etc titanium
stock throttle body
block"
b18b
low compression pistons and rings
aftermarket rods
stock crank
stock sleeves
drivetrain:
stock b16 tranny
quaife lsd
500hp axles
4 puck clutch
turbo kit
sc61 s housing
ramhorn turbo manifold
3in down pipe and catback
1000cc injectors
walbro 255 lph
going to be tuned by hondata
going to be tuned on pump gas..what power can i make?and how should my quater mile look like on slicks?
Modified by danilorecinos at 12:37 PM 7/21/2007
Modified by danilorecinos at 12:44 PM 7/21/2007
Modified by danilorecinos at 12:46 PM 7/21/2007
Old Jul 22, 2007 | 04:31 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: what can i expect to run with my set up? (danilorecinos)
10.7's on 540 with a crappy short time, you should see low 11's easy.
Old Jul 22, 2007 | 04:34 PM
DaveF's Avatar
Default Re: what can i expect to run with my set up? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">10.7's on 540 with a crappy short time, you should see low 11's easy.</TD></TR></TABLE>
sir, you are way off. that setup is good for 2's
Old Jul 22, 2007 | 04:37 PM
Default Re: what can i expect to run with my set up? (dturbocivic)
Yah ive been told low 11's at about 125 mph+ or close to 130 mph..my tuner said a high ten is possible if i get good launches..
Old Jul 22, 2007 | 04:38 PM
2's? i hope you dont mean 12's lol..because i can run twelves with a stock gsr motor on boost..
Old Jul 22, 2007 | 05:43 PM
DaveF's Avatar
seriously 2's, you should be able to reach to the moon with that spaceship power !
Old Jul 22, 2007 | 11:11 PM
NativeSon's Avatar
I was gonna say 6's, but you're probably right. More like 2's.
JDMCIVIC919
Transmission & Drivetrain
Mar 28, 2012 07:59 PM
Gold DA9
Nov 15, 2011 04:26 AM
hondamn1320
62
Feb 10, 2010 11:14 AM
mrx
Oct 12, 2004 10:11 AM
boost fed ls
Aug 9, 2004 03:05 PM
