D16y8 into eg
i just both a y8 engine with tranny what do i need to swap this into my 95 honda civic dx -
engine did not come with harness
another ? can i use the stock motor mounts for the y8?
oh yeah can i use my stock throtle 2 cause it did not come with 1?
plz help and yes i searched
add VTEC solenoid and pressure switch wiring, relocate IAT into intake arm if using the Y8 intake manifold, reuse your injectors and distributor, you won't use the knock sensor on the back of the block or the crank angle sensor by the crank pulley.
HondaNooby24
24
Aug 18, 2013 04:54 PM
