Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
a/c grind type noise upon startup of car.
Old Jul 20, 2007 | 01:57 PM
EJ8VTECFTW's Avatar
Default a/c grind type noise upon startup of car.
when i got in my car earlier, i started it and it was idleing at 1500 rpms, the a/c was switched to off as soon as i turned it on it made a grind type clunk type noise (its hard to describe) and then my rpms went back to normal. my a/c blows cold and everything seems to work just like it should, am i supposed to not turn the a/c to off or something when i turn the car off?
i have an 07 Si coupe
Old Jul 20, 2007 | 02:11 PM
I:_Drive's Avatar
Default Re: a/c grind type noise upon startup of car. (EJ8VTECFTW)
prolly the clutch on the a/c engaging the compressor. mine does it too not sure if its bad or not.
Old Jul 20, 2007 | 02:25 PM
EJ8VTECFTW's Avatar
Default Re: a/c grind type noise upon startup of car. (I:_Drive)
oh ic, btw i noticed i have the recirculate on when i had the a/c off and your not exactly posta do that and then turn the a/c on in recirc. mode. it should be on normal a/c when you start the car most likely..this could be contributing to the noise im guessing?
Old Jul 20, 2007 | 03:18 PM
rolow's Avatar
The ac should be off completely before you start the car. Turning off the a/c when you get out of the car is a good habit to get into.
Ive heard allot of people on the board describe the problem you are having. I haven't had the noise yet so ill be of no help on that.
Old Jul 20, 2007 | 03:21 PM
EJ8VTECFTW's Avatar
Default Re: a/c grind type noise upon startup of car. (rolow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rolow &raquo;</TD></TR><TR><TD CLASS="quote">The ac should be off completely before you start the car. Turning off the a/c when you get out of the car is a good habit to get into.
Ive heard allot of people on the board describe the problem you are having. I haven't had the noise yet so ill be of no help on that.</TD></TR></TABLE>
what im saying is, i think it has only happend when i turn the car off, leave it in recirculation mode, and get in it the next day turn the a/c back on in recirculation mode and it makes that noise..
Old Jul 20, 2007 | 04:20 PM
Demonis's Avatar
mine does the same thing, just the compressor grabbing on startup...
Old Jul 20, 2007 | 04:24 PM
EJ8VTECFTW's Avatar
Default Re: a/c grind type noise upon startup of car. (Demonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">mine does the same thing, just the compressor grabbing on startup... </TD></TR></TABLE>
good to know its usual and im not the only one, it made me freak out for a few minutes, i searched the topic some, but not many results, thanks for the input guys
Old Jul 20, 2007 | 05:17 PM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
Mine did it last week, I just started turning mine off before I get out.
Old Jul 23, 2007 | 06:12 AM
chiggin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rolow &raquo;</TD></TR><TR><TD CLASS="quote">The ac should be off completely before you start the car. Turning off the a/c when you get out of the car is a good habit to get into. </TD></TR></TABLE>
I've heard this before but never a reason for it. Why should the a/c be off before starting the car?
Old Jul 23, 2007 | 07:10 AM
Type X's Avatar
This is a common issue, turning the A/C on too soon will cause it.
let the car idle for a bit before u activate it and this will alleviate the issue.
Old Jul 23, 2007 | 07:11 AM
rolow's Avatar
Default Re: a/c grind type noise upon startup of car. (chiggin)
it helps with wear and tear
Rick Overton
May 7, 2017 03:39 PM
HoUTX98GSR
18
May 24, 2010 11:07 AM
aznnikeballer887
Oct 30, 2009 09:27 AM
fergs96integra
Jul 30, 2006 07:15 PM
ToFu-DeLiVeRy
Jul 20, 2004 08:16 PM
