Goin to the track
Old Jul 19, 2007 | 10:21 AM
guero2craze's Avatar
Default Goin to the track
So im goin to the track for my first time and want some pointers and info
I have a 94 gsr wit 115xxx
The mods:
Exedy stage 1 clutch
ACT chromoly 12lb flywheel
Rota slips wrapped with Nittos Gen
K&N short ram intake
Greddy header 4-2-1
Dropped on Konis/HR sprt
I just want to know what to launch on (RPM) and just some good pointers, im goin wit against ma friend 5th gen h22 Prelude...i think he might get me since were draggin in a 1/4 mile but all for fun
Any input welcome
Member im a newb when it comes to a drag strip
Old Jul 19, 2007 | 10:25 AM
adamrich33's Avatar
Default Re: Goin to the track (guero2craze)
he want get you as long as you can drag, as far as launching its going to depend on track humidity and tires, i would start at 3k and go from there, if you got good reflexes start rolling out at the last light
Old Jul 19, 2007 | 10:33 AM
Default Re: Goin to the track (adamrich33)
So i kno this might sound weird but i heard you have to heat your tires up, the question is how do you burn out, i know pull the ebrake...wet tires and rev and drop clutch but ma question is wat rpm do i drop the clutch...if im wrong correct me plz
Old Jul 19, 2007 | 10:53 AM
Tornadom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guero2craze &raquo;</TD></TR><TR><TD CLASS="quote">So i kno this might sound weird but i heard you have to heat your tires up, the question is how do you burn out, i know pull the ebrake...wet tires and rev and drop clutch but ma question is wat rpm do i drop the clutch...if im wrong correct me plz
You will be better off not heating up your tires... you have a street tire, which works best at lower temps. A burn-out would heat your tires up too much. I can cut 2.1's on cold Kumho 712s (I haven't been to the strip on my Bridgestones yet).
Old Jul 19, 2007 | 10:58 AM
b18LS's Avatar
Default Re: Goin to the track (Tornadom)
Yes and from my limited launching experience solo 2ing, feather the clutch out, DONT dump it. Massive wheel spin is not your friend.
Old Jul 19, 2007 | 12:20 PM
Default Re: Goin to the track (b18LS)
wat do you mean feather?
Old Jul 19, 2007 | 12:57 PM
Schister66's Avatar
Man U FTW
feather the clutch...kind of like slipping it. You wont have enough traction on a launch if you drop the clutch
Old Jul 19, 2007 | 02:39 PM
wegotmorrison's Avatar
haha, I think depending on the Preludes mods, your car should be faster, but i dont know if your gonna be able to drive it..
Old Jul 19, 2007 | 02:57 PM
grundle's Avatar
if you have street tires dont do a full burn out. maybee just spin the tires a little to get any rocks out of them before you go but don't smoke them. i ran on street tires the first time i went. I made the mistake of doing a full burn, smoke and all, the first time up. spun like crazzy next time i went up, no burn, was alot better. the last time the track official came up and said i had some little rocks stuck to my tires this time and the last so i just spun them a littel to get them off. was the best launch of the 3. did the same thing every time after that. works like a charm.
Old Jul 20, 2007 | 04:15 AM
So suspensions wise, should i do full stiff on the back and half stiff on the front or wat?
Old Jul 20, 2007 | 04:41 AM
spets's Avatar
just full stiff all the way around.
Old Jul 20, 2007 | 05:24 AM
AWD Terror's Avatar
If you have street tire, make sure you stay out of the water. It will collect in your tread, then once you stage it will drain off making you sit in a puddle of water for your launch
vlc92189
Sep 19, 2006 08:21 PM
jinteg730
Aug 9, 2004 12:11 PM
CarbonfiberR
Aug 15, 2002 11:17 AM
sackdz
Jun 21, 2002 10:38 AM
91ReXSI
Nov 15, 2001 10:58 AM
