02 Si Hatchback Won't Run Past 4k RPM's
Old Jul 19, 2007 | 09:04 AM
dizriz's Avatar
Old Jul 20, 2007 | 03:14 PM
wegotmorrison's Avatar
Default Re: (dizriz)
CHANGE YOUR OIL.
Old Jul 20, 2007 | 04:33 PM
20CiviC02Si's Avatar
That is what we call "LIMP MODE", i bet you are throwing a CEL! Check your fluids. If your fluids are fine, then head over to a place that can read the code through the OB2 port. Find out what that code is an fix it.
Also disconnect the negative battery cable. Let it sit for 1minute. This will reset the ECU. Reconnect and start the car up. If the CEL is still active then, move on to what i previously posted. It has worked for me before.
stc876
Oct 2, 2013 10:53 PM
1sikhatch
Jan 31, 2010 09:06 AM
ThefirstPACT
Dec 20, 2003 12:26 PM
GeorgeY
Jun 29, 2003 08:59 AM
ModAddict
Feb 7, 2003 07:06 PM
