*help* cant jump ecu code
Old Jul 19, 2007 | 12:32 AM
kdt3's Avatar
Default *help* cant jump ecu code
right now i have a cel that is preventing me from getting a tune.
i am on hondatas200. motor is h22a4 with p28 obd1 harness and obd1 distributor.
i tried to stick a paper clip in the service connector and everytime it just makes the CEL light go away but it never flashes. also sometimes it makes the srs n abs light go on.
since that way didnt work, i downloaded hondatalogger to see if i can check my CEL through laptop. i get everything hooked up to find out that there is "connection error". i re dl everything n try it on 2 other laptops..same thing happens, error.
so i need help on 2 things here.
1)why doesnt the light flash?
2)why is there connection error when attempting to hook up s200 to laptop? software required?
Old Jul 19, 2007 | 01:44 PM
kdt3's Avatar
so out of 22 views..no one with the knowledge?
Old Jul 19, 2007 | 02:22 PM
98vtec's Avatar
moderator emeritus
Default Re: *help* cant jump ecu code (kdt3)
bad ecu?
Old Jul 19, 2007 | 02:25 PM
xxmastermindxx's Avatar
from the way you wrote that, sounds like you are jumping the connector with your ignition already in start position? i'm not sure if that would change anything but try jumping the connector, then stick your key in and switch to on.
Old Jul 19, 2007 | 05:42 PM
kdt3's Avatar
..i **** hope its not bad ecu..i tried to jump it the right way..wire in first then stick key in n put in start position.
any info would be greatly appreciate. i hate not having a tune. car feels slower than bolt on h22
Old Jul 19, 2007 | 05:51 PM
98vtec's Avatar
moderator emeritus
Default Re: (kdt3)
take the cover off the underside of the ecu and see if you see any burns on the board.
Old Jul 19, 2007 | 06:25 PM
kdt3's Avatar
my eyes arent that good so take a look mr.blake.
Old Jul 19, 2007 | 07:05 PM
M2B4's Avatar
Default Re: (kdt3)
i would say test a known good ecu. with hondata it comes with software when you buy from them so my guess is software why you cant connect.
Old Jul 19, 2007 | 07:10 PM
kdt3's Avatar
yea that could be it, but why doesnt option 1 work?
Old Jul 20, 2007 | 11:37 AM
kdt3's Avatar
need more information to why 1 and 2 dont work
Old Jul 20, 2007 | 11:38 AM
Mykizism's Avatar
have you talked to jason kevin?
Old Jul 20, 2007 | 02:48 PM
kdt3's Avatar
ive called him, texted, and IM him on aim. no asnwer. i would go up to the shop but he would be too busy to take a look at my car..s0o iono tired of this crap. too many complications
Old Jul 21, 2007 | 05:39 AM
bigz187's Avatar
Default Re: (kdt3)
Any updates Kevin? Btw...why is that pic dated 2002?
Old Jul 21, 2007 | 11:52 AM
kdt3's Avatar
nada man. the date setting on the camra is wierd.
Old Jul 21, 2007 | 12:04 PM
dagle's Avatar
Default Re: (kdt3)
try jumping again w/ a diff conductor.. paperclip didnt work for me but stripped telephone line did (copper ends) and u have to have it in delicately to make sure theres a connection.
lol i was thinking of wetting the ends just a tiny bit but it worked so i dint have to. and thats prob a bad idea
4DALOOKS92
Apr 16, 2016 07:46 AM
z6hatchboy
Sep 16, 2010 04:16 PM
jonathan13
Aug 24, 2010 11:19 AM
TwoKSiR
Dec 21, 2009 11:17 AM
westcoaststyle
Oct 1, 2002 12:55 PM
