MAP SENSOR PROBLEM ON 95EX wit JDM B16A
Old Jul 19, 2007 | 12:27 AM
AnDy327's Avatar
Default MAP SENSOR PROBLEM ON 95EX wit JDM B16A
SO I SWAPPED A B16A INTO MY 95 EX. I GOT THE MOTOR OFF HMO.COM
EVERYTHING WENT SMOTH UNITLL I GOT CODE 3 (map sensor)
AFTER LOOKING FOR IT FOR A WHILE I REALIZED I DIDNT HAVE ONE
I BOUGH ONE AND HOOKED UP THAT LITTLE VACCUME LINE OFF THE THROTTLE BODY BUT IT STILL GAME ME THE CODE...
I HEARD ABOUT EXTERNAL MAP SENSORS ON OLDER TEGG'S BUT KINDA IFFY ABOUT IT. SOMEONE PLEASE HELP ME!!
IF YOU KNOW WHAT I NEED CAN YOU ALSO TELL ME WERE TO GET IT,
P.S I wanna do this with out having to change my throttle body. Thats a last option!
Old Jul 19, 2007 | 04:10 PM
AnDy327's Avatar
Default Re: MAP SENSOR PROBLEM ON 95EX wit JDM B16A (AnDy327)
Anyone????
Old Jul 19, 2007 | 04:16 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnDy327 &raquo;</TD></TR><TR><TD CLASS="quote">SO I SWAPPED A B16A INTO MY 95 EX. I GOT THE MOTOR OFF HMO.COM
P.S I wanna do this with out having to change my throttle body. Thats a last option!</TD></TR></TABLE>
not sure exactly if jdm civics were set up like here int the states, but 92-93 civics have a map sensor on the firewall.
you won't have to replace you throttle body, just get the bracket and the external map sensor and call it a day.
as for still having the code, either you still have a faulty sensor or you need to reset the ecu, or it's a code 5. to reset the ecu, disconnect the battery for about 5 minutes and the ecu should be clear.
Old Jul 19, 2007 | 07:56 PM
AnDy327's Avatar
Default Re: MAP SENSOR PROBLEM ON 95EX wit JDM B16A (Sandro)
Ive got the whole External Map sensor done. And after re-seting the ECU. Im still gettin the code. I read im supposed to have 5volts to the wire that goes into the sensor. But when I checked it I only had 1.45
Do you guys know what could cause his problem?
cyrways
Oct 20, 2007 11:13 AM
Jake92eg
15
Sep 19, 2007 05:57 PM
JibOnALib
12
Sep 14, 2005 11:51 AM
NotPhilTran
Apr 27, 2004 07:08 AM
zerofighter777
May 27, 2002 01:43 PM
