H22 VIbration
I have a H22 in my 96 civic coupe
It vibrates like crazy!!!
How can i stop this to be very minimal or even zero vibration.
I'm not sure what kind of mounts it has but there not hasport mounts i know that for certain... would buying those mounts kill my vibration issues cuz it gets to your hands after a while. Or am i just SCREWED
By the way i brought the car w/ the h22... so another question is was the motor possibly not put in right or is this a common problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">M1SCO15: when it idles and drives
Let's keep it in here for reference sake. When you're in neutral and rev the engine, does the vibration get better or worse?
The firm (likely polyurethane) mounts are probably what is causing your vibration. I don't know of any companies that would make a softer mount for your swap. Maybe somebody else can chime in.
Make sure that everything is properly tightend down and the mounts don't look worn or beat up.
would these be any better?
http://streetimports.com/produ...d=871
these are the same mounts but just on ebay and same company and i got my b18c from here
http://cgi.ebay.com/ebaymotors...ZWDVW
So some poly urethane you think would be better I'll hope some one swings by like you said
What I'm saying is that you probably already have polyurethane mounts. These are much harder than the soft rubber mounts that the car came with stock. Because of this, more vibration from the engine is transferred into the car. If the mounts were softer (rubber), you wouldn't get as much vibration.
What kind of mounts do you have? Any pics?
Well i have one pic I had the car on ebay i was trying to sell it but i'm keeping it so take a look at the pic its not a great pic
http://cgi.ebay.com/ebaymotors...63759
Sry i misunderstood about the urethane... So some rubber ones hmmmm... i'm sure its been done I'll find it
H22Stew
Dec 13, 2008 01:25 PM
