sway bar??
hi everyone, first time posting topics on hondatech, running a 99civic coupe.. was wondering if i needed a new front sway? or strut bar. i was doing abt 90mph in da freeway and notice my steeringwheel got really lose ? any suggestions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ess0n23 »</TD></TR><TR><TD CLASS="quote">it will fix itself if you go faster</TD></TR></TABLE>
don't listen to him
don't listen to him
haah yeah it was obvious not to listen to him.. going faster
well yeahs. da alignment is perfect? goes straight. well my car is lowered so yeah, with alil negative camber
did you think i was serious? i know going faster wouldnt make it better it was a joke. im guessing the problem isnt the sway its the alignment. im sure a sway would help but it will stilll vibrate like crazy.
lolz we were kiddin as well? jus something to say.. like i said before O.o.. alignment is fine? wheels are fine only thing i can say is.. itz pretty much lowered a inch off da wheels.. umm itz not that it vibrates.. the steeringwheel gets really loose? i also heard it was normal..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ibazndude »</TD></TR><TR><TD CLASS="quote">da alignment is perfect? goes straight.</TD></TR></TABLE>
Just because it goes straight, doesn't mean the alignment is perfect. When was the last time you got one? You could also need a wheel/tire balancing. If you drive like an *** and/or have old tires, then might be worn unevenly. It could even be your wheel bearings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 »</TD></TR><TR><TD CLASS="quote">Just because it goes straight, doesn't mean the alignment is perfect. </TD></TR></TABLE>
Thank god. x3
Did you get an alignment when you lowered your car?
Thank god. x3
The car wasn't made to go 90mph...especially on freeway with other drivers.
But to answer your question...it could be a number of things...alignment out of whack, toe might be out of whack, tire issues, etc. etc.
Halo
22
Jan 5, 2005 05:23 PM
