b16 ys1 trans. What Lsd to use.
Old Jul 18, 2007 | 02:36 PM
Civic89stdB16's Avatar
Default b16 ys1 trans. What Lsd to use.
I have a b16 ys1 cable trans with no grinds. Is there any oem lsd i can use in it. If so where can i get one new at. If not what is a good lsd for cheap. Thanks
Old Jul 19, 2007 | 01:47 AM
Dalon honda's Avatar
Default Re: b16 ys1 trans. What Lsd to use. (Civic89stdB16)
If they dont have a factary limited slip then you need to deside what your going to be doing with the car I do know from exp. dont get a fantom grip they dont work but if your doing lots of drag you should pony up the dough and get a cazz there like $1,000 and you have to use HEAVY oil like GL5 and it will click like somthings breaking but its not its just the limited slip locking and unlocking when you turn but you wont break it and it will work great.
Old Jul 19, 2007 | 03:37 AM
Default Re: b16 ys1 trans. What Lsd to use. (Dalon honda)
the car is going to be full drag race exept for like twice a month. Going all motor ls/vtec. I was going to get a richmond spool but its a tir e eater. Is an obx a good lsd. I am looking for a lsd the wont break the bank.
Old Jul 19, 2007 | 03:38 PM
bump
Old Jul 22, 2007 | 08:13 AM
bump
Old Aug 13, 2007 | 04:32 AM
aladdin's Avatar
bump
Old Aug 13, 2007 | 06:08 AM
4g hatch's Avatar
u can get a lsd from a cable y1,and its oem. also alot of people have luck with obx even with there bad name,just expect little problems that may need adjusting
Old Sep 17, 2007 | 05:20 AM
Default Re: (4g hatch)
where can i buy a new y1 lsd at
Old Sep 17, 2007 | 05:53 AM
Furyof4's Avatar
Default Re: (Civic89stdB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic89stdB16 &raquo;</TD></TR><TR><TD CLASS="quote">where can i buy a new y1 lsd at</TD></TR></TABLE>
Nowhere...any b16 lsd will fit.
Quaife, obx, kaaz, ats, cusco, etc.
Old Sep 17, 2007 | 08:50 AM
Default Re: (Furyof4)
so a obx 99-00 civic si will fit.
Old Sep 17, 2007 | 09:17 AM
Sliced Beard's Avatar
The YS1 is essentially the same as any other hydrauluc B series trans. You can even install a gearset out of a hydro trans into a YS1 case.
Old Sep 17, 2007 | 12:32 PM
Default Re: b16 ys1 trans. What Lsd to use. (DirtySol)
thanks
Old Sep 17, 2007 | 01:20 PM
Gearspeed-Performance's Avatar
Save up some $$ and get a Quaife. Do not get a Kaaz for drag racing. They will tell you that they are not made for it themselves.
Any clutch type LSD is made for mainly road racing for its vast adjustability. You can adjust and use some of them for Drag but, you will need a rebuild in 1-2 years depending on how much abuse you subjected it to.
If you get a Helical diff(Quaife)....no special fluids or maintenance...just install...clearance and go
Stay away from the OEM LSDs like the Y-1....Remember that the LSD is almost 20years old and good luck finding anything to rebuild it. Also Remember that the Y-1 is not Compatible with the YS-1 Transmissions. They are two different animals. The FD ratio on a JDM YS-1 is 4.40 and the FD ratio on the Y-1 is 4.27. Also the Countershafts are different.
Beware of some of the bad information on the site....try to stick to the specialists or OG's....they won't steer you wrong
Modified by GearSpeedEF7 at 2:30 PM 9/17/2007
Old Sep 18, 2007 | 03:53 AM
Default Re: b16 ys1 trans. What Lsd to use. (GearSpeedEF7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF7 &raquo;</TD></TR><TR><TD CLASS="quote">Save up some $$ and get a Quaife.
whoa mang, where have you been.....havn't talked to you since my transmission whoring days back in college.
and to OP, listen to this advice and if you have any build questions or questions on how to check clearnaces and whatnot, shoot me a PM, I will be happy to help.
Old Oct 7, 2007 | 08:31 AM
WVTURBOCRX's Avatar
Here is one for sale.
https://honda-tech.com/zerothread?id=2118754
Old Oct 8, 2007 | 10:41 AM
lunatics209's Avatar
i think you can run the itr lsd. i met this guy at pomona last year and he claims he is running the itr lsd in his ys1 tranny.
Old Oct 8, 2007 | 11:07 AM
Bense's Avatar
get an obx lsd, a hydro b-series LSD will fit your ys1 cable trans, the only thing you need to know is how many bolts are on the ring gear.
an acura parts catalog will tell you the number of bolts.
if it's the same number as a LS/b16 trans, then get an ls/b16 obx lsd.
if it's the same number as a gsr/type R....gsr/itr differential.
I regret buying my quaife, I should have gotten an obx and put the extra 500+ elsewhere.
Old Oct 8, 2007 | 12:36 PM
Default Re: b16 ys1 trans. What Lsd to use. (lunatics209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunatics209 &raquo;</TD></TR><TR><TD CLASS="quote">i think you can run the itr lsd. i met this guy at pomona last year and he claims he is running the itr lsd in his ys1 tranny.</TD></TR></TABLE>
You can run it but be sure to have a Type R or GSR Hydro ring and pinion handy...It is not just a bolt in and go. You have to change the ring gear and pinion. because the bolt pattern is larger. You can get by with just changing the ring gear but, it is better to change things in a matched set to avoid a whining tranny
Old Dec 10, 2007 | 03:21 PM
I found out that the trans is a gsr cable ys1 so do i still need to change the ring gear. thanks
Old Dec 11, 2007 | 08:17 AM
If you are going to run a Type R LSD you will need to change the ring gear. They have a different inner diameter. The Type R has a larger inner diameter'd ring gear.
Old Dec 11, 2007 | 09:33 AM
4g hatch's Avatar
after talking to gearspeed a while back just take his advice save,bite the bullet,and get a Quaife its the last one youll ever buy and you cant get a better guarentee anywhere thats what im gonna do just gotta wait till tax returns
Old Dec 11, 2007 | 12:30 PM
Default Re: b16 ys1 trans. What Lsd to use. (4g hatch)
if i buy one for a gsr hydro it will bolt right in or no. thanks
Old Dec 11, 2007 | 05:38 PM
4g hatch's Avatar
they make them for cable and hydro's. the good thing is no changing around the countershaft. talk to gearspeed he'll get you right
Old Dec 12, 2007 | 07:22 AM
GSR Hydro and Type R share the same larger inner diameter ring gear sizing.
DEADLYACURACCY
Transmission & Drivetrain
Feb 4, 2015 06:59 AM
Freemananana
Mar 19, 2014 09:39 AM
Tomdata
Mar 27, 2007 01:40 PM
eviled
14
Mar 20, 2007 05:17 PM
hondatuner123
May 16, 2006 08:16 PM
