what's in a tune-up
Old Jul 18, 2007 | 01:50 PM
vietkangta's Avatar
Default what's in a tune-up
when people bring their cars in for a tune-up what gets change/replaced or worked on?
Old Jul 18, 2007 | 03:55 PM
B16b-EJ8's Avatar
Default Re: what's in a tune-up (vietkangta)
Depends on the shop, some have different packages. To me a tune up should consist of:
New Plugs/ new plug wires/ new distributor cap and rotor
Oil change
Top off all fluids
Check and replace belts (alternator, A/C)
Possible new fuel filter
Clean or replace air filter
Thats just me though
Old Jul 18, 2007 | 05:02 PM
ekb16's Avatar
check the brakes
coolant flush
brake fluid flush
rotate tires
change cabin filter if car has one
Old Jul 18, 2007 | 06:02 PM
92_civic's Avatar
Default Re: (ekb16)
owner's manual gives a good indication of what services need to be performed at what mileage, between that and the previous service history of the car you should be able to determine what needs to be "tuned up"
when a customer calls me for a tune up, generally we are talking about tuning up the engine
plugs
wires
cap/rotor
air filter
fuel filter
cabin filter (if applicable)
oil change (includes check and top off fluids)
to me that is pretty much your standard tuneup, some cars require more or less depending on age and mileage, but you should also perform a thorough inspection of the vehicle as well
Old Jul 18, 2007 | 10:14 PM
t0p_sh0tta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietkangta &raquo;</TD></TR><TR><TD CLASS="quote">when people bring their cars in for a tune-up what gets change/replaced or worked on?</TD></TR></TABLE>
Coming from a former shop manager, there's no such thing as a tune up.
It all depends on the car. If you're looking for an extensive tune up, then here's a list:
- brake flush
- clutch flush
- tranny fluid change
- coolant flush
- oil change
- air filter
- spark plugs
- spark plug wires
- air filter
- distributor cap/rotor
- fuel filter
- radiator hoses
- a/c, alternator and p/s belts
Old Jul 19, 2007 | 12:33 AM
vietkangta's Avatar
Default Re: what's in a tune-up (t0p_sh0tta)
alright thanks guys.
Old Jul 19, 2007 | 10:44 PM
kojinwah's Avatar
not to jack... but some great info would be ... for the guys who do tune ups their selves.. where do you guys go shopping for your parts?
ie: local stores, internet, whatever..
Old Jul 19, 2007 | 10:47 PM
91DA9's Avatar
Default Re: what's in a tune-up (kojinwah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kojinwah &raquo;</TD></TR><TR><TD CLASS="quote">not to jack... but some great info would be ... for the guys who do tune ups their selves.. where do you guys go shopping for your parts?
ie: local stores, internet, whatever..</TD></TR></TABLE>
I have always trusted Napa myself, but lately it seems as if the quality of their parts is no better or worse than the stuff you can get from big chain stores (Autozone, Advance, Checker's, etc.)
There are certain parts that I would only go OEM for, but those are far and few in between.
Old Jul 19, 2007 | 11:09 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietkangta &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks guys.</TD></TR></TABLE>
if you want service on that car in your sig i'd rec:
replacing:
spark plugs
air filter
oil
atf
coolant
brake flush
adj valve lash
cradle seals
valve cover grommets
valve cover gasket
fuel filter
pcv valve
check leaky seals- dist o-ring etc
check cap/rotor/wires
check brakes
check cv boots for tears or cracking
rotate tires
check condition of tires
adj tire psi
if you havent done the timing belt yet
replace:
t-belt
balancer shaft belt
water pump
crank/cam/oil pump/balancer shaft-seals
drive belts
while you're at it or if you havent done so
replace:
all hoses
and t-stat
you need to be more specific on what kind of a "tune-up" you want
oh and BTW i wouldnt use anything other than oem honda parts..you'll thanks yourself in the end
Old Jul 20, 2007 | 09:55 AM
thesmogman's Avatar
Default Re: what's in a tune-up (onepoint6i)
A plain and simple tune up consists of...
Cap and rotor
Spark plugs
Timing check/adjustment.
If I asked for a tune up this is what I would expect.
Old Jul 24, 2007 | 11:46 PM
vietkangta's Avatar
Default Re: what's in a tune-up (thesmogman)
how much should i estimate on the costs?
Old Jul 25, 2007 | 12:20 AM
onepoint6i's Avatar
on what the t-belt or oil change??
Old Jul 25, 2007 | 11:12 AM
vietkangta's Avatar
the whole tune up?
Isnt timing belts around 250?
Old Jul 26, 2007 | 06:14 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietkangta &raquo;</TD></TR><TR><TD CLASS="quote">the whole tune up?
Isnt timing belts around 250?</TD></TR></TABLE>
depends on where you go..
Old Jul 28, 2007 | 12:43 AM
vietkangta's Avatar
whats the cheapest i can get around the bay area?
ButtersNZ
Honda CR-V & Element
Nov 17, 2015 09:38 AM
Moshimoto racing
Dec 28, 2005 09:30 PM
EF4lyfe
Sep 27, 2004 03:59 PM
Thasty
Oct 4, 2003 08:12 PM
migs
Dec 9, 2002 03:38 PM
