driver window off track...how do i?
Old Jul 18, 2007 | 01:00 PM
B18cHatch06's Avatar
Default driver window off track...how do i?
this is a manual not power window...it has gotten off track some how, and cant seem to figure out how to get the window crank handle off so i can pull the whole door panel off
any help would be appreciated...thanks
Old Jul 18, 2007 | 01:40 PM
PinoyxEJ6's Avatar
Default Re: driver window off track...how do i? (B18cHatch06)
there is a clip on the inside of the window handle thingy to roll the windows down. You have to pop that off first to get the window handle off.
Old Jul 18, 2007 | 01:41 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
A spring clip holds the window crank handle in place. Use a small tool with a hook to pull the clip to release it. Put the tool in the side where you grasp the handle.
Edit: ^^^Beat me to it.
Old Jul 18, 2007 | 04:24 PM
PinoyxEJ6's Avatar
Default Re: driver window off track...how do i? (tech8)
ohhhh yeah tech8! Well there is a v-shaped clip on the inside of the plastic window crank handle. You can ether use a allen key, flat head screw driver,etc, basically anthing that is long and that can fit in the gap between your crank handle and the door panel. So, once you see the clip on the inside. You are going to try to pluck it out and than it should slide right off and than you can take off the plastic window crank handle. BEAT THATTTT!!! hahahaha
Old Jul 18, 2007 | 04:56 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: driver window off track...how do i? (PinoyxEJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">
Edit: ^^^Beat me to it. </TD></TR></TABLE>
I was just meaning that you posted before I did.
Old Jul 18, 2007 | 05:23 PM
PinoyxEJ6's Avatar
oh snaps.. LOL GOT ME BAD DUDE!
dc2sexy's Avatar
ya it was a sucked trying to get my wrench in there when i changed the regulator
Old Jul 18, 2007 | 06:57 PM
PinoyxEJ6's Avatar
Default Re: driver window off track...how do i? (dc2sexy)
where can you purchase a cheap or used Manuel Window Reglator for a 97 civic dx 2 dr?
Old Jul 18, 2007 | 08:36 PM
1993civic's Avatar
there is a little clip in the handle take that off and then take the panel out and put the window back in track.
Morasso
Sep 10, 2009 05:31 AM
LSEGHATCH
Jun 1, 2005 05:40 AM
spicoli
Jun 8, 2004 03:59 PM
okman16
26
Nov 9, 2003 12:48 PM
Mentat Ghola
Jan 11, 2003 04:47 PM
