my coolant and condensor fans won't turn on?
Old Jul 18, 2007 | 12:45 PM
philosofy1's Avatar
Default my coolant and condensor fans won't turn on?
i have a 89 accord. i recently noticed that when i stop my a/c gets hotter and so does my engine. when i start driving everything becomes cool again.
i have checked my fuses and replaced the cooling fan relay, thermostat and radiator cap. i haven't had a chance to test the fan motor yet, but my question is, are they some how wired together? if one goes out then the other is bad too? will i have to replace them both? or is there some hidden relay i am unaware of?
this is my daily driver, grocery getter, kid picker upper. i really need to get this going right.
Old Jul 18, 2007 | 12:53 PM
The-Kid's Avatar
Ummm get a wire and hook them up to the battery. And check both. They might be out or spin slowly.
Old Jul 18, 2007 | 12:59 PM
philosofy1's Avatar
Default Re: (The-Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Kid &raquo;</TD></TR><TR><TD CLASS="quote">Ummm get a wire and hook them up to the battery. And check both. They might be out or spin slowly.</TD></TR></TABLE>
i popped the hood and watch them as the car began to raise in tempature, no go.
i just wonder if some how they are wired together. if the wires run to the coolant fan first then to the condensor fan.
Old Jul 18, 2007 | 03:54 PM
The-Kid's Avatar
Default Re: (philosofy1)
Well the fans are not connected together like some car. Some connecters are below the fan shroud. But u can test them at the same time. Usually with A/C on, both fans come on at the same time.
Also did you do a flush? new coolant and stuff? And did you also bleed the air outs of the system?
Modified by The-Kid at 7:35 PM 7/18/2007
Old Jul 19, 2007 | 03:45 PM
philosofy1's Avatar
Modified by The-Kid at 7:35 PM 7/18/2007</TD></TR></TABLE>
i have new coolant in the motor, recently had a 2 hoses pop and i replaced the thermo at the same time. the system was bled during the process and coolant is flowing, i can see it when i take the radiator cap off.
Old Jul 19, 2007 | 07:52 PM
hondadude's Avatar
Default Re: my coolant and condensor fans won't turn on? (philosofy1)
Dx Lx or LXi?.......different schematics
Old Jul 19, 2007 | 10:39 PM
philosofy1's Avatar
Default Re: my coolant and condensor fans won't turn on? (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Dx Lx or LXi?.......different schematics</TD></TR></TABLE>
LX
emilio2488
Honda Civic (2006 - 2015)
Jun 13, 2014 06:30 AM
TheNasty0ne
Jul 17, 2005 12:42 AM
JDMSi92
Jul 13, 2005 06:41 PM
slowassR
Aug 27, 2004 09:37 AM
DragII
Mar 9, 2002 12:31 PM
