k-series swap info
it's obvious the 01' - 05' is not as cheap to do a motor swap as the old days of the b-series. i've heard a couple of different ways to do a k-series into the em. is it possible to get all the mounts and crossmember off of the civic si (02 - 05') or the rsx and is there any writeups on doing the wiring harness for this chassis, i have breifly searched but all info i found didn't quite define what had to be done and yes i know that hasport has kit, but oem is nice too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGvsEM »</TD></TR><TR><TD CLASS="quote">it's obvious the 01' - 05' is not as cheap to do a motor swap as the old days of the b-series. i've heard a couple of different ways to do a k-series into the em. is it possible to get all the mounts and crossmember off of the civic si (02 - 05') or the rsx and is there any writeups on doing the wiring harness for this chassis, i have breifly searched but all info i found didn't quite define what had to be done and yes i know that hasport has kit, but oem is nice too</TD></TR></TABLE>
You won't be able to run OEM, without removing the stock mounts and welding in some new ones.
thanks, i'll have to do some additional searching on the harness. i can't pay someone to do something that i can do and also put some heart into. that and the rest of the money is for pistons and lsd/5.062 fd
Here's some info. that might come in handy for the harness.
http://www.xproductionz.com/k20swap/k20swap.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">http://www.xproductionz.com/k20swap/k20swap.html</TD></TR></TABLE>
Woah... some good reads there.
Nice to see you on here matey.
