what is the hole on the intake manifold for?
Old Jul 17, 2007 | 11:59 PM
RiversideS13's Avatar
Default what is the hole on the intake manifold for?
what is the tube that goes from the intake manifold body into the hole that is between #3 and #4 tube? what is the consequence without it?
thanks
you can see the picture here
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Jul 18, 2007 | 02:33 AM
92ehatch's Avatar
Default Re: what is the hole on the intake manifold for? (RiversideS13)
that tube connects to the black box on the back of the engine block.
its for your PCV valve.
the PCV valve connects to the top of the tube (the "Hole" you speak of")
then a vacuum line runs from the pcv valve to the intake manifold
Old Jul 18, 2007 | 09:37 AM
Default Re: what is the hole on the intake manifold for? (92ehatch)
thanks for help. what is the consequence of not having pcv valve intact?
Old Jul 18, 2007 | 10:17 AM
gd99em1's Avatar
you will have a huge vacuum leak and idle at about 3k
Old Jul 18, 2007 | 11:08 AM
Default Re: what is the hole on the intake manifold for? (gd99em1)
thanks!!! it explains why i have crazy idle .....
SnailSlowDelSol
Feb 21, 2016 09:26 PM
eglude
Sep 14, 2012 11:53 AM
RiversideS13
11
Jul 21, 2007 08:11 AM
egerdahl
Jul 28, 2005 06:30 PM
