!!!!!!HELP!!!!!!!!
Old Jul 17, 2007 | 04:58 PM
gangstacritta's Avatar
Default !!!!!!HELP!!!!!!!!
My crank turns but stops. It won't turn continuosly. What does that mean? Somebody help!!!!!!!!
Old Jul 17, 2007 | 05:00 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by critta***** &raquo;</TD></TR><TR><TD CLASS="quote">My crank turns but stops. It won't turn continuosly. What does that mean? Somebody help!!!!!!!!</TD></TR></TABLE>
The compression wont let you do it by hand, its really hard to turn it that way.
We're going to need some more info tho on your cars year, model, engine, and modifications ont he motor.
Old Jul 17, 2007 | 05:02 PM
instructor74's Avatar
Default Re: !!!!!!HELP!!!!!!!! (critta*****)
how are you trying to turn it? if with a socket on the crank pulley you might have hit tdc on one of the cylinders. To make life easy remove all 4 spark plugs and try turning it over by hand if the motor still will not turn all the way over then you have a bigger problem
Old Jul 17, 2007 | 05:11 PM
I thought the spark plugs had something to do with it! I'll try it. Thanks! Its a stock D16Z6. I was trying to find TDC and put on timing belt.
Old Jul 17, 2007 | 06:53 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: !!!!!!HELP!!!!!!!! (maze_yang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maze_yang &raquo;</TD></TR><TR><TD CLASS="quote">O yea i can help you on that one. Point is: GET A NEW CAR!</TD></TR></TABLE>
Or just pull the spark plugs out so the compression moves in/out.
Old Jul 18, 2007 | 02:51 PM
Default Re: !!!!!!HELP!!!!!!!! (ek forever guy)
Figured it out. Whoever put the camshaft on put it on wrong. They didn't even put a cam seal on it either.
Old Jul 18, 2007 | 02:55 PM
DecentCivicZ6's Avatar
B A N N E D
this guy already needs banning, you outa check out what he said lil while ago on a nother thread..lol
Jimster480
Nov 28, 2010 08:34 PM
blue89hatch
May 7, 2008 01:57 PM
b18b1ef8
Apr 26, 2008 03:59 PM
T--Rex
Oct 21, 2004 05:49 PM
See Are X
Nov 9, 2003 09:09 PM
