Fans Stay Running?
Old Jul 17, 2007 | 03:15 PM
projectwidow's Avatar
Default Fans Stay Running?
After driving for awhile and the engine is hot, whenever I park the car the radiator fans stay running. They stay running for a good bit too, like 3-5 minutes sometimes. Somebody told me that the water temp sensor could be bad. Anyone know what could cause the fans to stay running?
Old Jul 17, 2007 | 03:34 PM
CHK4TIX's Avatar
Default Re: Fans Stay Running? (projectwidow)
Mine has been doing that a lot lately. I would also like to know if I need to worry about something
Old Jul 17, 2007 | 06:36 PM
esedulerp5tenin's Avatar
Default Re: Fans Stay Running? (CHK4TIX)
mine does too especially after the turbo and in this insanely hot weather. i think it stayed on for about 10 minutes after a 10 minute drive in 90 degrees
Old Jul 17, 2007 | 07:01 PM
darkspector2.0's Avatar
I'd make sure you're full on coolant
Old Jul 17, 2007 | 07:02 PM
russlan44's Avatar
Default Re: (darkspector2.0)
my fan wont even turn on after a short or long drive, and doesnt over heat, or anything
Old Jul 17, 2007 | 07:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">mine does too especially after the turbo and in this insanely hot weather. i think it stayed on for about 10 minutes after a 10 minute drive in 90 degrees</TD></TR></TABLE>
Yup. I noticed it more after the turbo and the hot weather also. The car isn't over heating or anything so maybe it just takes that long to cool the car down?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 &raquo;</TD></TR><TR><TD CLASS="quote">my fan wont even turn on after a short or long drive, and doesnt over heat, or anything</TD></TR></TABLE>
Mine never really did either. But now with the turbo, hot weather, and the ac running, I don't know if the car can keep up. haha
Old Jul 18, 2007 | 04:37 AM
carnot's Avatar
Default Re: (projectwidow)
what is your radiator and fan setup like? OEM?
Old Jul 18, 2007 | 05:06 AM
cb7tougeracer's Avatar
Default Re: (carnot)
my accord would do that i think its just cooling the engine down i wouldnt worry
Old Jul 18, 2007 | 05:11 AM
gogunkergorilla's Avatar
the fan is supposed to stay on if the coolant temp is over 220° f when you shut the car off.
Old Jul 18, 2007 | 06:01 AM
Lewdin' Incognito's Avatar
Default Re: (gogunkergorilla)
Like others said - that's what it is supposed to do. Make sure you're topped off on fluids, keep an eye on your temp gauge if you're still concerned. I wouldn't be, personally.
Old Jul 18, 2007 | 03:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carnot &raquo;</TD></TR><TR><TD CLASS="quote">what is your radiator and fan setup like? OEM?</TD></TR></TABLE>
I got stock radiator and Flex-a-lite slim fans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogunkergorilla &raquo;</TD></TR><TR><TD CLASS="quote">the fan is supposed to stay on if the coolant temp is over 220° f when you shut the car off.</TD></TR></TABLE>
Oh ok. I will check and see if I need to add a little coolant but I wasn't too worried about it since it wasn't overheating.
I just wanted to see if others were experiencing this and what would cause them to stay running since they didn't do it before. Thanks
the.hamburglar
Jun 15, 2008 11:27 AM
totsie7944
May 2, 2008 10:23 AM
A Tribe Called Honda
Feb 16, 2008 08:00 AM
Turbo_Mike
Aug 2, 2006 08:25 PM
jdecks23
May 4, 2004 01:23 PM
