OBD0 TO OBD1 QUESTION...
Old Jul 17, 2007 | 01:47 PM
totoshatch's Avatar
Default OBD0 TO OBD1 QUESTION...
OK I HAVE A STUPID QUESTION, I HAVE A 88 HATCH WITH A DPFI ENGINE HARNESS WHICH HAS MISSING PIGTAILS. I ALSO HAVE ABOUT 3 OBD1 ENGINE HARNESSES THAT WERE IN THE BACK SEAT OF THE CAR FOR SOME ODD REASON. IS IT POSSIBLE TO INSTALL THAT HARNESS IF I HAVE THE MALE AND FEMALE PLUGS TO DO IT WITH? THANKS IN ADVANCE
Old Jul 17, 2007 | 02:47 PM
gibsanez's Avatar
Default Re: OBD0 TO OBD1 QUESTION... (totoshatch)
CAN YOU YELL LOUDER AS I CANNOT UNDERSTAND WHAT YOU'RE TYPING!@!!!!11!!
But seriously, if install you mean replace all the obd0 plugs with obd1 plugs, than sure, if you want to and think you can.
Old Jul 17, 2007 | 02:53 PM
totoshatch's Avatar
Default Re: OBD0 TO OBD1 QUESTION... (gibsanez)
sorry i have to type with caps at work and i dont like having to change back and forth. i dont want to just change the plugs i want to just use the whole harness and plug it in to the 3 major ones, the two by the passenger side relay box and the one by the master cylinder. i also have the pigtails it would go to so it would be way cheaper than buying a dpfi harness changing it to mpfi and then go with the distributor problem
Old Jul 17, 2007 | 03:05 PM
HondaFerris's Avatar
no, you can't use the obd1 harness. if your on a budget, the cheapest way will be to just find a new dpfi harness and convert it to mpfi...if not, easiest way will be to hit up Rywire.com and they will hook you up with what you need.
Old Jul 17, 2007 | 05:42 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totoshatch &raquo;</TD></TR><TR><TD CLASS="quote">sorry i have to type with caps at work and i dont like having to change back and forth. i dont want to just change the plugs i want to just use the whole harness and plug it in to the 3 major ones, the two by the passenger side relay box and the one by the master cylinder. i also have the pigtails it would go to so it would be way cheaper than buying a dpfi harness changing it to mpfi and then go with the distributor problem
Guy above me is right, sorry dood, you have to use the original engine harness and then modify that.
Old Jul 19, 2007 | 08:47 AM
totoshatch's Avatar
ok i dont doubt you all but ive seen it done on a crx but i cant find the forum of where i saw it. I was just trying to work with what i got, but you all are right, the best thing is to but the original harness and go from there. thanks
Old Jul 19, 2007 | 09:16 AM
totoshatch's Avatar
ok i found a picture of a crx that is posted by a guy named JDMBOLONI. how can i get a hold of him to see if he can help me out??
stealthmodeSI
19
Feb 20, 2020 04:06 PM
pokmijn
Aug 2, 2008 11:15 AM
ozrednsx
Dec 13, 2007 10:55 AM
Honda_Fanatic
Oct 29, 2007 08:52 AM
4crx4me
Jan 31, 2004 07:36 PM
