Adjustable Cam Gears back to Stock 99 Civic SI (How To)
Old Jul 17, 2007 | 01:28 PM
neoc03's Avatar
Default Adjustable Cam Gears back to Stock 99 Civic SI (How To)
Is there a way to tell if my adjustable cam gears were adjusted without adjusting the timing properly. Also how to I set it back to stock? Do I have to use the timing light or will the computer automatically adjust since I'm sending the timing back to stock. Please Help.
Old Jul 17, 2007 | 03:32 PM
Padawan's Avatar
Darth ModerVader
Default Re: Adjustable Cam Gears back to Stock 99 Civic SI (neoc03)
Can you elaborate a little regarding what you're asking?
If you want to check your base ignition timing, you'll need a timing light.
What timing are you looking to set "back to stock"? Base ignition timing, or cam timing?
Old Jul 17, 2007 | 06:18 PM
neoc03's Avatar
Default Re: Adjustable Cam Gears back to Stock 99 Civic SI (Padawan)
I have adjustable cam gears and the intake and exhaust are both retarted 1/2 a degree.
The motor doesn't sound like it running right and it shakes when its at idle (the motor itself).
I want to get the cam timing and base ignition timing back to stock.
My main goal is to eliminate the shaking and get it back to purring the way she should.
Old Jul 18, 2007 | 05:28 AM
Padawan's Avatar
Darth ModerVader
Well if you want to bring it back to stock, just set the cam timing to 0,0, then use your timing light to set the base ignition timing to 16 +/- 2 degrees BTDC. Don't forget to jump the service connector when setting the ignition timing.
Old Jul 18, 2007 | 07:50 AM
neoc03's Avatar
BTDC is Before Top Dead Center right?
I may sound like a newb (because I kinda am when it comes to timing), but is the service connector the 2 pin connector under the kick panel that you can use to make your CEL blink to get a code readout?
Also the will the timing light come with instructions?
Modified by neoc03 at 9:09 AM 7/18/2007
Old Jul 18, 2007 | 07:57 AM
Padawan's Avatar
Darth ModerVader
Yes, yes, and yes.
Also, here's an ignition timing how-to: http://www.c-speedracing.com/h...g.php
Old Jul 18, 2007 | 08:09 AM
neoc03's Avatar
Thanks so much dude. I've been going nuts trying to figure this out.
johnwohl
Apr 1, 2008 07:29 PM
has-t
Jul 1, 2003 09:58 AM
Jockobo
Jan 23, 2003 03:48 PM
redcxhatch
Nov 16, 2002 08:04 AM
