idle on my acura integra jdm b16a vtech
Old Jul 17, 2007 | 11:31 AM
THALLS23's Avatar
Default idle on my acura integra jdm b16a vtech
my idle bounces from a grand to 500 and i replaced tps and map sensor and did a valve adjustment does anyone know what next i should replace
Old Jul 17, 2007 | 12:06 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: idle on my acura integra jdm b16a vtech (THALLS23)
You could have a vaccum leak. Take your intake off and with your hand cover your throttle body completely while the engine is on and if it doesnt die out you have a vaccum leak.
Old Jul 17, 2007 | 06:17 PM
THALLS23's Avatar
Default Re: idle on my acura integra jdm b16a vtech (5_Lug_B)
ok if that wouldn't work what would be another solution but thanks for that cuz someone before said it might be a vaccum but i forgot to check it
Old Jul 17, 2007 | 08:05 PM
slowcivic2k's Avatar
Check all the vacuum nipples on the intake manifold and make sure they are connected to the right components.
I you have an FITV on that engine make sure it is connected and working properly.
Unplug the IACV and let it idle, it should maintain a 450rpm idle without it, if it dies, you may want to clean your PCV valve. If it is higher you have a leak, and you will need to ensure all your vacuum hoses are connected correctly.
Old Jul 18, 2007 | 06:16 AM
4g hatch's Avatar
did u adjust the tps
Justinmnhall
22
Sep 6, 2013 03:40 PM
ED9man
Jan 10, 2007 07:13 PM
h22831
Jul 18, 2005 06:36 PM
GreensleeperB16
Aug 5, 2003 07:41 PM
Metal_SOL
Nov 19, 2002 07:05 AM
