How to install a AEM wideband with bosch 02 sensor...need help guys
Old Jul 17, 2007 | 11:01 AM
b20beast978's Avatar
Default How to install a AEM wideband with bosch 02 sensor...need help guys
I just recently purchased an aem wideband and i am having a little difficulty trying to wire the tach. It brings 4 diffrent color plugs one white, blue, black and red. The 4 wire's on my d16y7 are totally diffrent colors so how would i know if i am wiring the heater wire to the correct place? any inputs would be appreacitaed thx!
Old Jul 17, 2007 | 12:40 PM
bump.. need some thelp
Old Jul 17, 2007 | 01:12 PM
Civic98KH's Avatar
with wideband you need a wideband o2 sensor...
Old Jul 17, 2007 | 01:47 PM
sohc-8's Avatar
did you buy the aem uego all-in-one wideband or just the wideband gauge. since you mentioned the four wires, then i think it is the gauge-controller wideband. you need to order a wideband o2 sensor from aem. the o2 sensor should have a connector that connects to the aem uego harness. then hook up the wires. red-ecu +12v, black-ground, white-0-5v output, blue-serial output(optional). you should download the manual from the aem website.
Old Jul 17, 2007 | 03:49 PM
yea i bought aem uego wideband....but i still dont see how im suppose to hook up the wires...so any red 12v will do? so do i wire the red to th battery since its 12 v, and the black to anywhere in the chasis? where would the white go ?
Old Jul 18, 2007 | 03:49 AM
sohc-8's Avatar
connect the red wire to the ecu power wire, so it only turns on when the ecu is on. the black wire goes to the chassis ground or to the ecu ground. the white wire is optional. you use it if you want to datalog or if you want a narrowband output to your ecu when your in closed loop. connect it as the o2 sensor input.
Old Jul 18, 2007 | 05:11 AM
thx man...so basically i just need to wire the power and ground..i didnt think it was that simple, but thx for all inputs recieved so far
Old Jul 18, 2007 | 05:49 AM
combz's Avatar
Default Re: (b20beast978)
you didnt really answer if you got the bosch o2 sensor or not.
If you did...all you have to do to get it working is wire it to your ignition and ground it. Then plug the harness for the sensor into the gauge. your all set.
http://www.tunertools.com/prod...s.pdf
Old Jul 18, 2007 | 05:52 AM
yes its the bosch 02 sensor that comes with the uego..so you reccomend wiring it to the ignition?
Old Jul 20, 2007 | 07:36 AM
bump for some help!
Old Jul 20, 2007 | 08:15 AM
Syndacate's Avatar
Get the AEM Wideband = Win.
Gauge w/o sensor = Useless Bullshit Lightshow (UBL).
h22_crx
Jun 27, 2006 01:39 PM
Mr.DC2TurBo
Dec 3, 2005 10:41 AM
BoostedJeff
Oct 18, 2004 05:46 PM
BoostedSi
Mar 23, 2003 09:13 AM
