half shaft tranny cap keeps popping out of place. and spilling tranny fluid
Old Jul 17, 2007 | 08:34 AM
mustang5.slow's Avatar
* B A N N E D *
Default half shaft tranny cap keeps popping out of place. and spilling tranny fluid
hey guys how is that cap supposed to be kept in place.
>>Im referring to the driver side half shaft.? that closes the gap around the half shaft where it connects to the tranny. It seemed to pop into place at first. but now it just snugs on and eventually just slide right off.. and i supposed to use some kind of adhesive.????
Old Jul 17, 2007 | 08:40 AM
95vxtealhatch's Avatar
Default Re: half shaft tranny cap keeps popping out of place. and spilling tranny fluid (mustang5.slow)
I'm assuming you mean the CV shaft won't stay in your transmission. There is a small metal clip on the end of your CV shaft the locks it into place inside the tranny. You gotta push it in until it pops into place. There should be like 1/4inch gap inbetween the shaft and tranny when its locked in place.
Old Jul 17, 2007 | 08:43 AM
* B A N N E D *
Default Re: half shaft tranny cap keeps popping out of place. and spilling tranny fluid (95vxtealhatch)
hey thaks for that answer...
but that not what i meant i edited my question for more detailed description.
Old Jul 17, 2007 | 09:11 AM
* B A N N E D *
bump for now
Old Jul 17, 2007 | 09:19 AM
instructor74's Avatar
I think that piece that you are asking about is just a dirt shield the sealing is done by the drive shaft seal
Old Jul 17, 2007 | 10:23 AM
* B A N N E D *
Default Re: half shaft tranny cap keeps popping out of place. and spilling tranny fluid (instructor74)
well in my case that is what holds the oil in place.
am i missing a piece on my half shaft.???
Old Jul 17, 2007 | 10:48 AM
Number 18 in this diagram is the oil seal
https://www.hondapartsdeals.co...M++12
Number 21 is the intermediate drive shaft on the small end of that there is a shield that you can't really see and that is the dust shield that I asked you about in your other post
https://www.hondapartsdeals.co...B++21
Modified by instructor74 at 12:52 PM 7/17/2007
Old Jul 17, 2007 | 11:11 AM
* B A N N E D *
number 27... https://www.hondapartsdeals.co...B++21
it clamps ontho the the 18 on the other picture. https://www.hondapartsdeals.co...M++12
and the makes a seal thogether. but the number 27 keeps popping off the the rubber seal. why does it keep doint this.
Modified by mustang5.slow at 12:26 PM 7/17/2007
Old Jul 17, 2007 | 11:15 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow &raquo;</TD></TR><TR><TD CLASS="quote">number 27...https://www.hondapartsdeals.co...B++21
it clamps ontho the the 18 on the other picture.https://www.hondapartsdeals.co...M++12
and the makes a seal thogether. but the number 27 keeps popping off the the rubber seal. why does it keep doint this. </TD></TR></TABLE>
You need to either put a space in between the URL and your text or you have to put URL tags.
Nobody can click on what you posted.
Old Jul 17, 2007 | 11:26 AM
* B A N N E D *
Default Re: half shaft tranny cap keeps popping out of place. and spilling tranny fluid (Syndacate)
kool
Old Jul 18, 2007 | 08:57 AM
* B A N N E D *
bump for ideas.?
Old Jul 19, 2007 | 09:11 AM
* B A N N E D *
bump for desperate need of ideas.
Old Jul 19, 2007 | 09:16 AM
Syndacate's Avatar
Make sure you're putting the axle in right - if you put it in wrong (and a lot of people do) you knock that stupid clip right off and then it doesn't seal for ****.
Make sure ur putting it in straight as hell, not crooked. Then make sure it "clicks" in.
Old Jul 19, 2007 | 09:27 AM
* B A N N E D *
Default Re: (Syndacate)
well i know exactly what clip you are referring to and i dont remember my half shaft having one but anyways is that clip supposed to keep the half shaft in on the fluid in&gt;???
Old Jul 19, 2007 | 04:31 PM
* B A N N E D *
bump for ideas.
sirEGhatch
Transmission & Drivetrain
Mar 24, 2010 01:27 AM
odidipissuoff
Mar 16, 2010 06:45 PM
93sivtec
Nov 19, 2007 02:11 PM
Nameless RB26
Nov 11, 2002 11:38 AM
