best Vtec controller.. Searched!!
Old Jul 16, 2007 | 12:23 PM
JDM_rolex's Avatar
Default best Vtec controller.. Searched!!
which is best?
easiest tuning?
easiest wiring?
this is a serious poll guys feel free to add any other vtec controllers please no messed crap poll choices..
Old Jul 16, 2007 | 02:37 PM
Relic1's Avatar
none of them are going to work as well or keep your car running the correction ignition and fuel settings as a tuned ECU.
Old Jul 23, 2007 | 01:07 PM
skateboard_ej8's Avatar
im hench irl
i heard its best to leave your vtec crossover point at stock settings unless u have a highly modded engine. No need for them if you engine is stock.
Old Jul 23, 2007 | 05:14 PM
vteczone's Avatar
vtec controller?? i didnt know people still want to even considerin on using one..lol
Old Jul 23, 2007 | 05:30 PM
zccr-xsi's Avatar
vafc whats that? chipped ecu FTW
Old Jul 23, 2007 | 05:31 PM
zccr-xsi's Avatar
Default Re: (esco562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 &raquo;</TD></TR><TR><TD CLASS="quote">i heard its best to leave your vtec crossover point at stock settings unless u have a highly modded engine. No need for them if you engine is stock.</TD></TR></TABLE>
BASED ON WHAT INFO?
Old Jul 23, 2007 | 07:55 PM
doood's Avatar
been there done that
Default Re: (zccr-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">BASED ON WHAT INFO?</TD></TR></TABLE>
based on the fact that if you raise or lower vtec on a stock engine you'll likely see a drop in power
http://www.phearable.net/tech/....html
Old Jul 23, 2007 | 08:18 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (doood)
Just listen to the poll
Old Jul 24, 2007 | 11:08 AM
im hench irl
Based on the fact that honda engineers spent countless hours tuning and hence theyre title engineering the best crossover point for the engine. Then your gona go and get a vtec controller and mess up your engine.. why? unless you have a highly modded engine and know what the hell your doing, you should leave your crossover point to the stock ECU settings
Old Jul 24, 2007 | 01:22 PM
zccr-xsi's Avatar
well i dont use a sorry *** vafc thats hack ****.well i reset the vtrec its at 4800 no lower and it seems to runs better far as i can tell.ive never puyt a car on the dyno and adjust vtec points yet.so i cant arggue with the power loss cause i havnt seen it first hand.
Old Jul 24, 2007 | 01:26 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">well i dont use a sorry *** vafc thats hack ****.well i reset the vtrec its at 4800 no lower and it seems to runs better far as i can tell.ive never puyt a car on the dyno and adjust vtec points yet.so i cant arggue with the power loss cause i havnt seen it first hand.</TD></TR></TABLE>
what engine do you have again? what are you using for engine management? how did you exactly reset vtec?
Old Jul 24, 2007 | 02:49 PM
Cruiserdude's Avatar
As many of you know, you have to use a dyno to find your optimal VTEC engagement point. Set your VTEC right at redline, and tune the engine throughout the rev range on just the low-rpm cam. Then, set it really low, say 4000rpm, and tune the VTEC cam from 4k to redline. Overlay the final dyno graphs from each cam, and the point where the tq-bands crossover is the optimal point to set your VTEC, its as simple as that. You can set it a tad higher to make it "kick" more noticeably, as Honda themselves tends to do, but that's how the optimal point is found. While you're not likely to see an increase in power by changing VTEC engagement if your engine is stock, you don't just wait until you've got a certain amount of power and then just guess where to set it. Do it right or don't touch that ****. And yes, I recommend a tuned OBD1 ecu.
Old Jul 24, 2007 | 02:55 PM
im hench irl
Default Re: (Cruiserdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cruiserdude &raquo;</TD></TR><TR><TD CLASS="quote">As many of you know, you have to use a dyno to find your optimal VTEC engagement point. Set your VTEC right at redline, and tune the engine throughout the rev range on just the low-rpm cam. Then, set it really low, say 4000rpm, and tune the VTEC cam from 4k to redline. Overlay the final dyno graphs from each cam, and the point where the tq-bands crossover is the optimal point to set your VTEC, its as simple as that. You can set it a tad higher to make it "kick" more noticeably, as Honda themselves tends to do, but that's how the optimal point is found. While you're not likely to see an increase in power by changing VTEC engagement if your engine is stock, you don't just wait until you've got a certain amount of power and then just guess where to set it. Do it right or don't touch that ****. And yes, I recommend a tuned OBD1 ecu.</TD></TR></TABLE>
sounds good
EliTe 93Lude
May 15, 2006 11:44 AM
sluger17
20
Mar 22, 2006 08:28 PM
gsrwpower
Mar 21, 2006 09:50 PM
bottlefed13
Apr 13, 2005 09:23 AM
s2kDinesh
Honda S2000
12
Jan 10, 2005 12:27 AM
