steering wheel starts shaking @ 50 mph +
Old Jul 16, 2007 | 01:59 AM
ef9_pr0jekt's Avatar
Default steering wheel starts shaking @ 50 mph +
When i drive on the freeway or go past around 50mph +, my steering wheel starts to shake. I don't know what it might be. Could it be a lose bolt or could it be my tires? Any help or feedback on this will be appreciated. Thanks
Old Jul 16, 2007 | 02:53 AM
90crxdriver's Avatar
Default Re: steering wheel starts shaking @ 50 mph + (ef9_pr0jekt)
my bet is on tires. I had a shake at 40/45 got new tires installed and it went away.
Also you might have lost the balance weight on one of the wheel.
I would take it to a tire shop and have them check the balance.
Old Jul 16, 2007 | 03:44 AM
g2tegsown's Avatar
I used to have that same exact problem with my teg, one day it just went away. (Shortly after it went my power stearing pump seized up)
Old Jul 16, 2007 | 06:06 AM
redefsir's Avatar
Default Re: (g2tegsown)
most def out of balance.
either a bad tire or lost weight or bent wheel..
good luck
Old Jul 16, 2007 | 07:42 AM
VtecSyndrome's Avatar
Default Re: (redefsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redefsir &raquo;</TD></TR><TR><TD CLASS="quote">most def out of balance.
good luck</TD></TR></TABLE>
yep, x2
I gotta change out my wheels cause there bent all to hell an shake like mad at high speeds
Old Jul 16, 2007 | 10:47 AM
Gearspeed-Performance's Avatar
Default Re: (VtecSyndrome)
Changed the front tires on my beater hatch...rebalanced them and viola! The shake was gone on my car. Give it a shot... The tires I had were old and cracking btw.
Old Jul 16, 2007 | 11:15 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (GearSpeedEF7)
ball joints can also cause the vibration, so if your wheels get balanced and you still have the problem, replace your ball joints to start.
Old Jul 16, 2007 | 12:42 PM
dize5411's Avatar
you might need new rotors i bought new ones when i did a break job and the tire shacking stop
Old Jul 16, 2007 | 03:50 PM
ian1006's Avatar
just hold on tighter...
Old Jul 16, 2007 | 04:07 PM
wagonstatus's Avatar
possibly tie rod. check all your lugs
Old Jul 17, 2007 | 03:23 AM
Very helpful information.. Thanks guys. Cheers
Old Jul 17, 2007 | 08:09 PM
SOHC LO's Avatar
does your shifter or anything other than the wheel vibrate and shake like the wheel? if so most likely JUST GET TIRES BALANCE!! thats all!
exz0n-.-
Nov 27, 2008 12:19 AM
People_Mover
Sep 24, 2003 03:28 AM
CereaLand
Feb 12, 2003 08:26 PM
Nuts
Jul 2, 2002 08:24 PM
Seann
Jul 29, 2001 02:22 PM
