Using cam caps from different head
Old Jul 15, 2007 | 12:14 PM
r1de4life's Avatar
Default Using cam caps from different head
OKay so i bought a type r head and when i got home i realized i was missing the cam caps above cylinder 1 so i took some off of my gsr head. I need to know what to do to make them work and how much the machine shop would generally charge me?
Old Jul 15, 2007 | 02:40 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Using cam caps from different head (r1de4life)
I didn't think that it was possible to line bore. There is no bearing for the cams. An increased bore would loosen the tolerance.
Old Jul 15, 2007 | 05:27 PM
slowcivic2k's Avatar
You might be able to have a machine shop take a micrometer at it to see if it is a huge difference in size, they may be able to hone them to match, not sure if this will take you out of spec or not, the tolerance is small.
Old Jul 15, 2007 | 06:20 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Using cam caps from different head (slowcivic2k)
I would worry about a head with missing cam caps anyway. If the owner was careless enough to misplace the caps, how did they treat the head?
Old Jul 15, 2007 | 07:47 PM
Default Re: Using cam caps from different head (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I would worry about a head with missing cam caps anyway. If the owner was careless enough to misplace the caps, how did they treat the head?</TD></TR></TABLE>
werd
Old Jul 16, 2007 | 02:40 PM
r1de4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">
werd</TD></TR></TABLE> wellnever mind i spoke with the seller and he found them and is shipping them to me tomorrow i was scared for a little bit
Muckman
Sep 11, 2011 04:58 PM
insaneconceptz
May 29, 2010 05:10 PM
crispy93
Mar 8, 2007 07:17 PM
JDM turbo DC
Mar 15, 2006 08:26 AM
BIG RICH
Jan 8, 2005 09:22 PM
