integra gsr lookin to make it a local drag car!
Old Jul 15, 2007 | 11:21 AM
jordan_civic's Avatar
Default integra gsr lookin to make it a local drag car!
OK...Anythink would help me now. I just bought myself and integra gs-r and I bet it needs a tune up and a ton of stuff. I want to atleast be able to get to 7000s rpm. I want to make it a local drag car, not that fast but still fast enough to drag some but drive dayly. Really anything you have to tell me would help!
thanks!
jordan
Old Jul 15, 2007 | 12:10 PM
Adriano's Avatar
Default Re: integra gsr lookin to make it a local drag car! (jordan_civic)
Double check to make sure that the motor is in good shape (timing best, no smoke, no knocks, fresh oil) and give it a good tune up. They come from factory with the rev limiter @ 8200rpm, so as long as the moto is healthy, it's not a problem to rev to 8200rpm. As for turning it into a local drag car, it all depents on what you want to do, ie: turbo, nitrous, allmotor and how mcuh $$ u want to spend.
Adriano
Old Jul 15, 2007 | 12:19 PM
Default Re: integra gsr lookin to make it a local drag car! (Adriano)
Yeah...I am going to get it tuned hopefully and get it cleaned up. I wanted to get it into the 13s and 14s. Whatever the easiest cheapest way is...
Old Jul 15, 2007 | 02:36 PM
Adriano's Avatar
You cheapest way would be to gut the car (big time weight loss) and put some sticky tires. What's your budget? I personally would buy a turbo kit and run low boost.
Adriano
Old Jul 15, 2007 | 02:39 PM
well the prob is this is my everday car that i want to take to the drag strip sometimes...
Old Jul 15, 2007 | 07:05 PM
dropcivic's Avatar
cheapest and easiest way, spray it.
Old Jul 15, 2007 | 07:55 PM
I B BANGGIN's Avatar
Default Re: integra gsr lookin to make it a local drag car! (dropcivic)
before you do anything i suggest you read up on the specs of your motor, make sure its good enough to do anything to and go from there....going the cheapest way isnt always the best way..
check with a local perfomance shop im sure they'll help you out..
Old Jul 15, 2007 | 09:17 PM
EKB18BPR3's Avatar
get urself
ebay cold air intake ($20)
ebay header ($60)
ebay 2.5" exhaut ($250)
and have fun until u getbored of the extra power. then build the bottom end according to ur preference
forged pistons ($5-700)
forged rods ($5-700)
sleeved block ($2000)
knife edged crank ($500)
main and rod bearings ($120)
new timing belt and water pump ($120)
nce u do that, build the head.
valve and springs ($6-800)
cams ($5-700)
cam gears ($200)
port and polish ($1-300)
then get an aftermarket intake manifold. ($3-500)
by now ushould have ur fuel system upgraded
fuel injectors ($200-1000)
fuel pump ($250)
regulator ($1-300)
fuel rail (optional) ($150)
then get things tuned. ($2-500)
then u get either a
better header ($500-1000)
turbo and its containts ($2-5000)
supercharger and its containts ($1-3000)
nos and its containts ($5-700)
after that u should have a kick *** car.
Old Jul 15, 2007 | 09:56 PM
f@sth@tch89's Avatar
Default Re: integra gsr lookin to make it a local drag car! (EKB18BPR3)
what the expletive is up with all these n00b like posts lately....all these help me build a drag car and i also want to drive it on the street posts.
Old Jul 16, 2007 | 03:52 AM
dj4monie's Avatar
Default Re: integra gsr lookin to make it a local drag car! (f@sth@tch89)
f@sth@tch89 -
Hey I drag my daily driver and I don't ask you how to make it faster more than likely because you don't have a clue, but that's okay -
jordan_civic -
We all have to start someplace and I would say buy a Helms manual for it and not a Chilton or Haynes -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Why Buy Original OEM? Why Helm Publications?
* Helm only sells manuals written by the manufacturer (Original OEM), designed specifically for your vehicle or equipment.
* Original OEM Manuals are more accurate and complete than any other service information available. OEM Manuals contain thousands of pages of diagnostic and repair information!
* These are the same manuals your dealer service center uses so you know you're getting the technical information needed to service and maintain your vehicle or equipment.
* Many OEM Manuals include diagramed repair and replacement procedures, electrical diagrams and training information.</TD></TR></TABLE>
Take EK's advice and try to buy as many USED parts as you can. Ebay and this forum go a long way in to helping you accomplish your goal.
Nitrous is the cheapest and easiest way, but if you have no clue on how to make it go faster and lack general car knowledge, I wouldn't suggest nitrous.
All Motor is costly but you can do 13's in a GS-R with basically only top end work, bolt-ons, a tune and stock bottom-end, full weight (minus spare tire and usual things you would remove at the strip)
The EASIEST way and I agree with Adriano, go with some type of simple forced induction. Even a JSRC will get you 13 second passes with a good exhaust, tune and some drag radials....
$500 for a used JRSC kit, might be some issues but unless the blower is toast, this is bargain. - http://cgi.ebay.com/ebaymotors...ZWDVW
Oh replace the ignition igniter as we just did that on my friends '94 GS-R... The one thing on Hondas that ALWAYS FAILS eventually.
Not always good to see somebody else join the ranks of "Me Too" but I guess that's okay -
Old Jul 16, 2007 | 04:44 PM
Old Jul 16, 2007 | 05:27 PM
sc4dr's Avatar
Default Re: integra gsr lookin to make it a local drag car! (rota92)
450hp 11 second street car here. Pretty reliable too
Old Jul 16, 2007 | 05:45 PM
ALL IMPORT's Avatar
Default Re: integra gsr lookin to make it a local drag car! (sc4dr)
do what i did at first.
now that u got a gsr make shure the motor is healthy.
then get u a nos kit. put 65shot on her (wet shot) walbro 255pump, better fuel regualtor
its a little pricey but get a quaif, can find them for around 600-700$ u can thank me later.
next buy u set of drag radials. i had bfg's with 17's .
that is all u will need to run mid 2 low 13's all day.
i had this exact setup on bone stock teg with gsr stock exhaust ect.. ran from 13.61 to a 13.49 all day. went to the track about 4-6 times a month & about 9 bottles of nos a month easily for about 1 1/2 years no problen then sold the car.
bear 90% cars that raced me. quaif goes a long way. also my car made 191whp with nos. not alot of power but the quaif made up for it.
tottal cost after i bought the car 1500$ cant beat that
Old Jul 16, 2007 | 06:34 PM
BlownHatch's Avatar
Default Re: integra gsr lookin to make it a local drag car! (ALL IMPORT)
600whp street car here
tony n.
May 6, 2005 06:23 AM
zeroz
Apr 17, 2005 03:05 PM
Regulata
Jan 27, 2005 05:35 PM
SMZ GSR
Jan 5, 2003 04:26 PM
ActiveAero
Aug 13, 2002 09:18 AM
