brake pad sounds after pad change?
Old Jul 15, 2007 | 11:09 AM
IntegraR0064's Avatar
Default brake pad sounds after pad change?
Hey guys,
Just changed the rear pads to Hawk HPS's, and I left the stock rotors due to autozone giving me the wrong rotors. Haven't done the fronts yet, that's what I'm abou to do. I took it for a quick road test though, and I had a question. Am I supposed to have brake pad noise when I'm driving around without the brakes engaged? It's obviously just a light pressure sound, but it is audible from the driver's seat. The rotors are obviously slightly untrue, from how the sounds sound, if you know what I mean. I don't notice any significant resistance on the wheels (if I put it in neutral and coast, I don't feel like I slow down any faster than before). Any input?
Also, can I change the rotors without changing the pads again, or will that cause reduced braking performance due to the pads re-bedding?
Thanks for any input!
Old Jul 15, 2007 | 12:02 PM
rjgerolaga's Avatar
Default Re: brake pad sounds after pad change? (IntegraR0064)
adjust the rear. located inside center armrest console or just keep on driving till it goes away.
Old Jul 15, 2007 | 01:48 PM
BMaDOHC's Avatar
Default Re: brake pad sounds after pad change? (rjgerolaga)
the pads will make noise for a while especially since you just did a pad slap without turning the rotors or replacing them. make sure you used a moly paste on the pads for noise reduction and greased the slides were the pads rest in. noise should go away.
Old Jul 15, 2007 | 10:39 PM
Circuit Star-29's Avatar
Default Re: brake pad sounds after pad change? (BMaDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMaDOHC &raquo;</TD></TR><TR><TD CLASS="quote"> make sure you used a moly paste on the pads for noise reduction and greased the slides were the pads rest in. noise should go away. </TD></TR></TABLE>
Expanding-----
Between the shims and the BACK of the pad...
Old Jul 16, 2007 | 08:43 AM
MOVE OVER's Avatar
Default Re: brake pad sounds after pad change? (Circuit Star-29)
did you screw the piston into the caliper enough, or did you get it close and then work the caliper with pads back onto the rotor?
I saw that done last week and it DEFINATELY made a difference.
PatrickGSR94
Suspension & Brakes
Jun 2, 2008 03:17 AM
Dogginator
10
Sep 1, 2005 09:09 PM
faSHOwidIT
Suspension & Brakes
Apr 18, 2005 08:49 AM
blitzteggsr
Apr 29, 2004 06:35 PM
functionFiRst
Oct 2, 2002 09:49 PM
