coolant passage leak
Old Jul 15, 2007 | 05:46 AM
stdefhatch's Avatar
Default coolant passage leak
are these seals or gaskets known to leak on back of block? and if so is hondabond good to use.
Old Jul 15, 2007 | 07:48 AM
ToeJam's Avatar
Default Re: coolant passage leak (stdefhatch)
If its leaking or if youre not sure about the seal pull it out and replace the o-ring. you can also use some hondabond for extra security. Hondabond will also help it slide into place. Good luck.
lmike6453
Mar 22, 2008 08:17 PM
HELLAnorcal
Dec 5, 2007 04:37 AM
stdefhatch
Jul 15, 2007 07:27 AM
OMG B16
Aug 27, 2005 08:20 PM
turbotime
Jan 3, 2004 04:42 PM
