trouble with crx, 1st gen b16
hi, new here, anyhow..
maybe someone can help ?
i just recently installed a b16 into my 88 crx, anyhow, started up, runs nicely
no ecu codes = good wiring ?
there is an oil leak, it's coming from the head, tranny side, looks to me like it is right under the distributer on the upper right side of the upper rad hose.. . anyone info on this ? i have yet to take the distributer off and see whats there ?
also, feels like the motor is lacking ? it sounds and runs good, lacking power ? i duno
r7@beyond.ca
r7@beyond.ca
What ECU are you running? The oil leak is either the cam seal on the end of the exhaust cam, or the o-ring on the distributor that seals it in the hole on the end of the intake cam.
I have the same thing. It's coming from the cam seal on the exhaust cam. Anyone know how easy this is to replace?
jB
jB
i was just too 'scared' to do it...
seeing it being done, i think i could have done it in my sleep now...
u NEED a torque wrench to torque the cam cap bolts down
post up for the rates, because there are 10mm and 12 mm bolts..
hth
edit: torque specs..
the 10mm on the outside are 8lb-ft and
the 12mm on the inside are 17lb-ft.
[Modified by Giuseppe, 4:09 PM 6/9/2002]
jared, whats on the intake side ? an oring, thats where it is coming from.. how do i change ?
take of dist. 3 bolts, and than how does the dist. come off?
do i have to take off the valve cover to change the oring ?
take of dist. 3 bolts, and than how does the dist. come off?do i have to take off the valve cover to change the oring ?
mark the position of the dizzy b4 u take it off...
take off the three bolts....pull the o ring off...
im assuming 90-93 teg or 90-91 si..
lube it with a little motor oil and slip it
on like a **** ring
on like a **** ring
ok..i'd have to see it to tell ya, but i had a heck of an oil leak around my VTEC solenoid after my b16 swap..i thought it was a cam seal or the o-ring at first. turned out my oil pump wasn't cutting off and the oil pressure was running way too high and blowing out the vtec solenoid gasket. here's what i would do if i were you..get a can of brake cleaner..spray off where the oil has leaked really good till it's nice and clean..start the car up and let it idle for about 5 minutes..get a good flashlight and watch til you see the leak start. this will only work if it's a pretty heavy leak (mine was) good luck dude.
and, supercivic, how did you fix your problem with the pump ? also, would you're vtec work with that oil pressure problem ?
thanks, i took dist. cap off, and it's wet wil oil inside, (would this affect performance?) , is there 2 o-rings ? one in the dist. ?
also, i cannot remove the dist. took out 3 bolts, disconnected the 2 connectors.. and tried to pull it off, but it is held still
i finally got it off
it was the pin.. that ISN'T supposed to be where it was.. due to someone putting the dist. on wrong , there is a ring that is supposed to prevent this from happening.. it was put on wrong... therefore pin was sticking out and preventing the dist. from being pulled out
also, pin sticking out = grinding into the aluminum = causing small groove = bad
i duno if this will affect anything ?
Reelizmpro
Oct 29, 2004 11:14 AM
Jesse H
Apr 11, 2002 07:22 PM
