Max Bore for Dart Block? (or can it be re-sleeved)
Old Jul 14, 2007 | 12:33 PM
Running925's Avatar
Default Max Bore for Dart Block? (or can it be re-sleeved)
Hey guys, i've got a dart block here that someone destroyed. it was 11.5:1 compression and their cams were to agressive and snapped the ends of the valves off. Anyways, i'm looking to use this block for my boosted car so that i can crank the boost up some more. The current bore is 84.5 and i'm looking at it thinking that it would have to be taken to at least 85.5 or 86mm to get it all cleaned up from the damage to the walls. How far is to far on a Dart block, or can i have it re-sleeved?
Old Jul 14, 2007 | 12:57 PM
non-VTEC's Avatar
Default Re: Max Bore for Dart Block? (Running925)
i do believe the sleeves are removable and replaceable (rather easily too).......contact dart about that
Old Jul 14, 2007 | 01:21 PM
Muckman's Avatar
Moderator in Chief
It would have to be really F'ed up to require a full 1.5mm to clean things up. Id like to see pics.
Old Jul 14, 2007 | 04:08 PM
Running925's Avatar
Default Re: Max Bore for Dart Block? (Muckman)
i'll try to snap some pix of it tonight & throw them up late tonight or tomarrow.
Old Jul 15, 2007 | 12:57 PM
Running925's Avatar
heres a pic of the most destroyed piston in the block. I'll run out & snap a pic of some of the broken valves as well.
Old Jul 15, 2007 | 01:11 PM
Running925's Avatar
so after you look at the block, your sitting there like this --> thinking, how on earth did that happen..
well here's your answer:
Old Jul 15, 2007 | 02:02 PM
Bigblockhatch's Avatar
The sleeves are replaceable on the dart blocks.I think they list them as dry sleeves so any machine shop should be able to replace
Old Jul 15, 2007 | 03:27 PM
Muckman's Avatar
Moderator in Chief
It wouldnt be so bad if it were those few BIG dings in the cyl wall. It'd be worth taking it to an engine shop to see how much they would have to bore it to remove all that. I bet its not as much as you think. Then just have em O-ring it if your worried about HG thinness between the cylinders.
Old Jul 15, 2007 | 05:29 PM
Running925's Avatar
i'm more concerned with the thickness of the cylinder walls if i bore it farther than it already is. current bore is 84.5mm
I'm thinkin i would rather have it re-sleeved and go back to stock bore so that i could boost the **** out of it!
Old Jul 15, 2007 | 07:30 PM
Jared's Avatar
I would cry if my Dart block looked like that.
Old Jul 16, 2007 | 01:34 AM
90dxhmt's Avatar
Default Re: (Jared)
Dart says 85mm so get it checked first might be able to get away with a .5mm over
Old Jul 16, 2007 | 05:11 AM
Running925's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">I would cry if my Dart block looked like that.</TD></TR></TABLE>
this is the reason i got it for free!
I just want it re-sleeved so that i can show him how it was meant to be used!
Old Jul 16, 2007 | 05:22 AM
LftyPitcher26's Avatar
Default Re: (Running925)
I know it's a Dart block but I don't know if I'd boost a 86mm block.That's kind of thin sleeve. Oh and the price for low comp. pistons are gonna be through the roof!! They'll probably have to be custom made so you'd probably be better off getting it resleeved or getting like a set of 5 or 6 custom pistons just in case!!
This is BLK JDM posting under my friend's SN here at work!!
Old Jul 16, 2007 | 07:29 AM
rmcdaniels's Avatar
Default Re: (LftyPitcher26)
Plenty of people run them at 86mm with boost, mine is at 85.5. If you want a sleeve replaced, then send it to Dart. I hydro-locked mine, stretched the main caps and split a sleeve at the bottom where one rod bent like a banana. A new sleeve cost $60 and Dart installed it and bored/honed the mains for $150 with a one-week turnaround. I talked to the guy at Dart and people send them back their blown up blocks all the time (mostly the Ford and Chevy blocks). They fix them back to factory specs quickly and get them back out there. Based on my experience with Dart, they really stand behind their product.
Old Jul 16, 2007 | 09:43 AM
Running925's Avatar
Default Re: (rmcdaniels)
i talked to dart today & got some great news. They told me that they would have to look at it & inspect everything but for 4 new sleeves replaced & preped & everything ready to go again it's going to cost me about 300 bucks. The told me that after they recieve the block & check everything, they will call me with an exact amount but that was their estimate over the phone.
I'm extreamly excited to hear about that because that means that i pretty much got a dart block for about 300 plus shipping.
for Dart
Old Jul 16, 2007 | 11:35 AM
90dxhmt's Avatar
Nice.Dart
Old Jul 16, 2007 | 02:03 PM
rmcdaniels's Avatar
That sounds about right, they take care of people who buy their blocks. I know the damage to my block probably would have wrecked a sleeved Honda block, but it cost $210 total to get it fixed. I was very happy to have the Dart at that point.
Old Jul 16, 2007 | 03:25 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">That sounds about right, they take care of people who buy their blocks. I know the damage to my block probably would have wrecked a sleeved Honda block, but it cost $210 total to get it fixed. I was very happy to have the Dart at that point.</TD></TR></TABLE>
That's incredible, makes me even happier that I have one.
Rickcrx
Feb 23, 2012 05:18 PM
EDLOVA23
Aug 3, 2010 11:50 AM
808DB1
Mar 30, 2008 11:52 PM
a1320addict
Nov 30, 2005 03:02 PM
Twenty36_1
Aug 14, 2003 12:32 AM
