d15b plug n play?
Which motor are you installing? I am currently swapping a d15b7 for a d15bz1. So, if you are interested I would be willing to swap ecu's and harness's. Your harness has the vtec-e solenoid, egr, O2's, and a few others that my harness does not have.
If you currently have a D series everything is plug and play....
You'll need:
Your motor mounts (if it doesnt come with any)
Your wiring harness (JDM harness has everything flipped arround)
A P08 ECU (a P28 will have to be modified to make the engine run properly)
You'll have to wire up VTEC
Go here..... http://www.d-series.org/forums...32597
You'll need:
i am installing the d15b but i have a sohc vtec head from a ex model so i think what im gonna do is put the head on the d15z1 motor and discard the z1 head i just need something with a little more go until i get done with my ls turbo swap
feel better when cuss? anyways. got the d15b in my car already not worrying about any of the other motor **** that i have. i got wrong information and did what i had originally planned...
MWLW20
Aug 10, 2009 02:01 PM
