Fog light harness
Old Jul 14, 2007 | 01:40 AM
Thizzed Out's Avatar
Default Fog light harness
for a 97dx civic. I've installed my lights and pluged everything up except 2 plugs. One plug is red, and the other is white. they both have brown connectors.
where would i plug them? excuse that red arrow
Old Jul 14, 2007 | 03:43 AM
Default Re: Fog light harness (Thizzed Out)
Modified by Thizzed Out at 6:29 AM 7/14/2007
Old Jul 14, 2007 | 06:46 AM
punk_0333's Avatar
You plug the #2 into B, and the #5 into E.
Old Jul 14, 2007 | 12:50 PM
Default Re: Fog light harness (punk_0333)
ive tried that and nothing..i checked both grounds and they are olright. no blown fuses. am i suppose to add a fuse somewhere?! any help. thanks
Old Jul 14, 2007 | 05:39 PM
Old Jul 14, 2007 | 06:10 PM
turtleman321's Avatar
i dont have foglights but from looking at the fuse layouts. you might want to try putting a fuse in the running light slot.
Old Jul 14, 2007 | 06:14 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thizzed Out &raquo;</TD></TR><TR><TD CLASS="quote">am i suppose to add a fuse somewhere?! any help. thanks</TD></TR></TABLE>
No, you have an inline fuse on your switch harness. Check if that's still good, then check if your relay is clicking.
Old Jul 14, 2007 | 06:17 PM
Default Re: Fog light harness (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtleman321 &raquo;</TD></TR><TR><TD CLASS="quote">i dont have foglights but from looking at the fuse layouts. you might want to try putting a fuse in the running light slot.</TD></TR></TABLE>
which slot might that be? i'll try it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
No, you have an inline fuse on your switch harness. Check if that's still good, then check if your relay is clicking.</TD></TR></TABLE>
yup the fuse is still got and i hear the clicking from the relay.
is there any way else i can wire these up?
Old Jul 15, 2007 | 10:42 AM
MARDC5R's Avatar
bump cuz i'd like to know if there was another way to wire them up too
Old Jul 16, 2007 | 12:51 PM
Default Re: Fog light harness (MARDC5R)
ive got them to work. There is a ground wire INSIDE the foglights thats suppose to touch the bulb. I guess they werent touching so i fixed it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MARDC5R &raquo;</TD></TR><TR><TD CLASS="quote">bump cuz i'd like to know if there was another way to wire them up too </TD></TR></TABLE>
i'd still also like to know
Old Jul 16, 2007 | 01:10 PM
StealthEK's Avatar
I Installed the factory foglight kit on my 2000 Civic, but i only remember having a brown connecter, my instructions were all in japanese so they weren't much help, I just plugged it in an open spot, i think it was C or D and it works perfect, Goes on and off with the key.
Old Jul 17, 2007 | 06:18 AM
MARDC5R's Avatar
congrats Thizzed....i havent had great luck getting mine to work.....i checked everything!!! i keep blowing fuses
im double checking those ground wired in the foglights where you found your problem tonight....
Old Jul 20, 2007 | 06:30 PM
any luck on your problem man?
Old Jul 21, 2007 | 08:08 PM
MARDC5R's Avatar
havent had a chance to check....i'm planning to check it out tommorow..
Old Jul 22, 2007 | 06:21 PM
MARDC5R's Avatar
Ok i finally fixed it!!! i got a new one for the fog light problem list....i check the ground connection like the problem you had.....it was fine.....i was just about to give up when i decided to check the connections.....the ground and hot wires were switched so when i was connecting it to the wireing on the car it was "ground to hot and hot to ground....i switched the connections and pluged them up and they work fine now.....im soo happy!!!
Old Jul 22, 2007 | 07:25 PM
tylerfoote's Avatar
Default Re: (MARDC5R)
were you talkin about fogs for a si?
Old Jul 22, 2007 | 10:34 PM
Chain Driven's Avatar
Old Jul 23, 2007 | 03:01 AM
Default Re: Fog light harness (Chain Driven)
good to hear man.
Old Jul 24, 2007 | 05:14 PM
honda instructions pdf if you want
19Honda91Sedan
17
May 10, 2020 01:20 PM
hkboy87
Mar 27, 2008 07:41 PM
g3teg97
Dec 30, 2006 09:41 AM
kyorishin
10
Nov 13, 2006 08:14 PM
ZkyLude
May 17, 2006 11:49 AM
