JDM EK9 Navigation Question...
Old Jul 13, 2007 | 11:01 PM
Boba Fett Jr.'s Avatar
Default JDM EK9 Navigation Question...
If I add one into a 96-98 Civic, would I have to do a whole conversion like switching over to the 99-00 A/C unit? Just a simple answer would be fine.
Thanks.
Old Jul 14, 2007 | 05:20 AM
mikeycivic's Avatar
Default Re: JDM EK9 Navigation Question... (Boba Fett Jr.)
i believe that would make it easier but not sure if its 100% necessary
Old Jul 14, 2007 | 05:25 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boba Fett Jr. &raquo;</TD></TR><TR><TD CLASS="quote">If I add one into a 96-98 Civic, would I have to do a whole conversion like switching over to the 99-00 A/C unit? Just a simple answer would be fine.
Thanks.</TD></TR></TABLE>
do a search, there was a whole write up on how to swap everything over.
Old Jul 14, 2007 | 06:25 AM
EK9Rider's Avatar
Default Re: JDM EK9 Navigation Question... (philosofy1)
jdm navigation will not work properly in the u.s.
the radio has different frequencies - if you were to swap you have to get the whole entire kit with the jdm navi - can't cut any corners on this one.
i'm not trying to knock it as i researched doing one in my 00 hatch - it just wasn't worth it because the system would not be compatible with u.s. streets
if you're going for show then go for it.
or you can always go with a pioneer set up.
Old Jul 14, 2007 | 07:38 AM
Yeah, I knew the Navigation wont work in the U.S. I was basically going for looks. But after reading that I will have to do a heater box swap and some other stuff from a 99-00 into my 96-98 Civic, I rather pass than go through all the trouble.
Thanks for you input guys.
6ghatch
Northeast (Sales)
Nov 27, 2007 07:37 PM
sleeper_pwr
18
May 16, 2007 07:42 PM
Punk rock mike
Aug 6, 2006 12:21 PM
EK-Chris
Mar 7, 2005 04:41 PM
CivHatchH22
12
Oct 31, 2004 08:53 PM
