Black Anadized Nuts Bolts Washers
Old Jul 13, 2007 | 07:43 AM
YoungMoneySi's Avatar
Default Black Anadized Nuts Bolts Washers
whuttup guys...do you know anywhere in southern cali...(i live in pasadena) that sells BLACK ANADIZED or OXIDE nuts and bolts? i installed my rear lip and i need black bolts .... please lemme know! thanks guys
Old Jul 13, 2007 | 07:54 AM
95ProjectEJ1's Avatar
Default Re: Black Anadized Nuts Bolts Washers (YoungMoneySi)
I work for an aerospace company and deal with plating houses that can perform anodize, but I do not know of any places that sell them complete.
97Ej6mike's Avatar
NEED black bolts for the lip or WANT black bolts. Any right sized bolt will do the trick. If you really want to mask the bolts, just spray paint them with some flat black paint/primer before putting them on, its that simple.
Old Jul 13, 2007 | 08:35 AM
Bense's Avatar
you will have a much easier time if you just paint them. aluminum anodized bolts are going to be hard to find.
Old Jul 13, 2007 | 09:37 AM
Default Re: (Bense)
ok i guess i will just have to paint them...i installed the lip already but the shiny bolts look wayyyyyyyyyy to obvious and out there from the rear. you dont have to be too far from me to see them. i called honda and those ******* want 3 dollars and something for the black shoulder bolts...fRock thaT!
Old Jul 13, 2007 | 09:49 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (YoungMoneySi)
Most metric grade 12 hardware has a black coating and allen type socket heads. I've got them at Lowes for pretty cheap to install a rear sway-bar. Only thing is they have a few little rusty looking spots on them, and I live in the middle of dry-*** las vegas...
Old Jul 13, 2007 | 10:04 AM
Archidictus's Avatar
Unceasing Measure
You can always use black rivets.
Old Jul 13, 2007 | 11:51 AM
Default Re: Black Anadized Nuts Bolts Washers (Archidictus)
yeah i some allen heads and waited on those until i found something else but if that is the case then i will just get those.
i dont wanna deal with having to paint bolts and having the paint chip off after time
Old Jul 13, 2007 | 07:34 PM
Bense's Avatar
it will be cheaper + easier to get the oem ones instead of specialty black anodized aluminum bolts.
zsiya
Oct 5, 2011 11:28 AM
Adrian Peterson
Wheels
Jan 30, 2011 11:23 PM
Adrian Peterson
Wheels
51
Jan 31, 2010 01:43 PM
WhiteOnRice
Dec 4, 2006 04:47 PM
central_driver
41
Jan 27, 2006 01:09 PM
