wont go into reverse...at all
Old Jul 13, 2007 | 04:33 AM
sprAyandprAy's Avatar
Default wont go into reverse...at all
My 92DA LS will not go into reverse at all, and grinds a bit going into 5th. This weekend I am doing a complete tuneup to it, which includes changing the tranny oil. I heard this may help, any other suggestion what it could be if this doesnt work?
Old Jul 13, 2007 | 04:47 AM
g0tgot's Avatar
new tranni>?
Old Jul 13, 2007 | 08:39 AM
turbo93da's Avatar
Default Re: wont go into reverse...at all (sprAyandprAy)
a rebuild or a new tranny
Old Jul 13, 2007 | 01:08 PM
GSR-TRBO-DA's Avatar
i see it all the time when people just shift into reverse and it grinds. if you are having trouble shifting just straight into reverse. shift first, second, then reverse and 9 times outta 10 will go in like butter. but if your transmission is already grinding i wouldn't change the oil because you might make it worse, i know it sounds crazy but if you drain out all the shavings that are probably in the gearbox it probably might not work at all. i have seen it happen, it is like when people complain with a automatic trans that it is slippin then they change the filter and fluid and instead of making it better it makes it worse.
do what you think is best>&gt)
Old Jul 13, 2007 | 01:34 PM
posHonda's Avatar
did you try double clutching to get it in reverse? when my reverse wasnt working very well i just started it in reverse.
since its like that already you might wanna try some syncromesh
Old Jul 13, 2007 | 02:56 PM
if none of the quick fixes work then it will just have to do without untill i get teh motor swap
Badger401
Jul 26, 2020 11:24 PM
alex_belarus
Nov 22, 2007 01:40 PM
str8JDMteggy
Jul 27, 2006 09:25 PM
Silkk Tha Shocker!
Jun 18, 2006 09:13 AM
Ross
Aug 20, 2001 07:24 AM
