97 civic - are there any tweeter mounts for the doors?
Old Jul 13, 2007 | 01:17 AM
seowitz's Avatar
Default 97 civic - are there any tweeter mounts for the doors?
anyone know if there are? or does everyone just mount cut a hole in the door panels and mount them that way? i'd rather not surface mount them
Old Jul 13, 2007 | 04:04 AM
B18C_EJ8's Avatar
EX Models came with tweeters in the sail panels of the door....
Old Jul 13, 2007 | 05:46 PM
chrisw85's Avatar
Mount them as near as possible to the mid-woofer to minimize time alignment issues. This will give you better SQ. Mounting them up higher can create reflections which can affect imaging in addition to time-alignment issues. There may be enough room under the stock plastic grille to fab up a mount to either slip right under or to put recessed into the grille.
Old Jul 14, 2007 | 12:07 AM
seowitz's Avatar
i'm not sure if there's room or not to mount it in the grille, if there isn't if i put them near by like a few inches up would that work?
also about kick panels, on the driver's side ones, has anyone ever had a problem kicking the panel all the time? is the panel getting in the way of the dead pedal area for those with a manual?
Old Jul 14, 2007 | 04:26 AM
JSPECSIR's Avatar
Default Re: (seowitz)
a guy came by my work one time, that made these little trim plates out of abs to mount his tweeters in the storage pocket right behind his mids. they were facing kinda up and back. looked pretty good, i didnt even notice them at first. pretty sure it was a 2 door also. wish i had pics.
Old Jul 14, 2007 | 07:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: 97 civic - are there any tweeter mounts for the doors? (seowitz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seowitz &raquo;</TD></TR><TR><TD CLASS="quote">anyone know if there are? or does everyone just mount cut a hole in the door panels and mount them that way? i'd rather not surface mount them</TD></TR></TABLE> Do you already have the speakers?
If so then the easiest/cleanest way is the hit the bone yards and find an EX, and get the "sails" and see if the tweeters you have can be made to fit them, otherwise mount them as close to the mids as possible, [as has been mentioned]
If you do not already have the speakers, and you do not want to cut your doors, get the EX "sails" and find component speakers with tweeters that will fit the "sails" or get a good 2way point source speaker like the Eclipse SP6500... http://www.eclipse-web.com/point/sp6500.html and you will not need to cut your door panel or use the "sails", [that place the tweeter a long way from the mid]. 94
Old Jul 16, 2007 | 12:04 AM
seowitz's Avatar
Default Re: 97 civic - are there any tweeter mounts for the doors? (fcm)
so anyone ever have any issues with the driver side kick panels?
i have infinity kappa 60.7cs components. maybe i'll just put a hole in above the mid
Old Jul 16, 2007 | 04:17 AM
B18C_EJ8's Avatar
I had the Q-Forms in my '98 Civic and I loved them.
You will, however, lose your dead pedal with them...
Old Jul 17, 2007 | 12:16 AM
seowitz's Avatar
ugh. well at least i know i'll hate them!
hole cutting time it is i guess!
Old Jul 17, 2007 | 05:02 AM
B18C_EJ8's Avatar
Why? Because you'll have to move your foot?
Old Jul 17, 2007 | 05:30 PM
seowitz's Avatar
Default Re: (B18C_EJ8)
YES!
Old Jul 17, 2007 | 05:59 PM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I had the Q-Forms in my '98 Civic and I loved them.
You will, however, lose your dead pedal with them...</TD></TR></TABLE>
Hey did the pod interfere with the clutch pedal at all? Did you have the 5.75 or the 6.5 ones?
Old Jul 17, 2007 | 07:17 PM
B18C_EJ8's Avatar
I had the 5 1/4" set, and they didn't interfere with the clutch pedal...
I loved them...
Takashi1978
Audio / Security / Video
23
Feb 13, 2006 05:08 PM
Haruspex
Feb 19, 2005 08:51 AM
SwissChEz82
Nov 17, 2004 10:20 AM
done
Dec 10, 2002 08:19 AM
ALF
Sep 14, 2001 10:01 PM
