How do you remove Primer over spray from a rim?
Old Jul 12, 2007 | 08:20 PM
Simple SOHC's Avatar
Default How do you remove Primer over spray from a rim?
Just bought some rims...all of them are clean except for one. It has some primer over spray on it. How can I remove the primer and not damage the rim. They Rota Jmags. Here are some pics:
Old Jul 12, 2007 | 08:24 PM
Hondizzle!'s Avatar
Default Re: How do you remove Primer over spray from a rim? (Simple SOHC)
I would think mineral spirits would be your best bet. I dont THINK it would damage the wheel at all. Somebody correct me if I am wrong.
miyagi's Avatar
i used a claybar and it got lithgt overspray off my fenders... you could try that.
Old Jul 12, 2007 | 09:27 PM
Default Re: How do you remove Primer over spray from a rim? (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">
lol. wheel forum </TD></TR></TABLE>
Had it in the Appearance/Cosmetic Forum...figured that might be a good place to start...but they moved it here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">rubbing compound or claybar + elbow grease LOL</TD></TR></TABLE>
Guess I'll try the claybar...I think I have some rubbing compound if that doesn't work.
Any other suggestions?
Old Jul 12, 2007 | 11:55 PM
D16SiHatch's Avatar
acetone or paint thinner will do the trick. shouldnt do anything to the rims at all i wouldnt think. and it should come right off without exerting much effort at all lol
Old Jul 13, 2007 | 12:53 AM
bobjohnson's Avatar
Default Re: How do you remove Primer over spray from a rim? (D16SiHatch)
Yeah those rims are polished aluminum (It looks like anyway), you should be able to use paint thinner no problem... If not, try a razor blade, flat against the rim, should be able to scrape it off but youd have to be careful about dragging it perfectly even along the metal so you dont leave any scrapes.
Old Jul 13, 2007 | 02:03 PM
kiddcarbuff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">acetone or paint thinner will do the trick. shouldnt do anything to the rims at all i wouldnt think. and it should come right off without exerting much effort at all lol</TD></TR></TABLE>goof off
Old Jul 18, 2007 | 06:21 PM
gsr dood's Avatar
Default Re: How do you remove Primer over spray from a rim? (kiddcarbuff)
laquer thinner, trust me i work at a shop, only thing that will take it off in 3 seconds!
Old Jul 18, 2007 | 10:02 PM
vtec8804's Avatar
* B A N N E D *
claybar x2...everyone says laquor thinner or w.e but if they were my wheels i wouldnt take any chances and claybar is almost effortless
Old Jul 19, 2007 | 12:02 AM
daralekt's Avatar
Default Re: (vtec8804)
thinner or clean-ez will work fine
Old Jul 21, 2007 | 09:14 AM
luckii's Avatar
spray some of that aircraft paint thinner and it should start to peel off on its own in 20 mins. get it at autozone or walmart.
Old Jul 21, 2007 | 02:34 PM
dude_123's Avatar
You guys are spending too much for any easy fix, just get a bottle of 90% alcohol and it will take it off.
Simple SOHC
Jul 16, 2007 07:30 AM
revlimiter
Jul 29, 2006 10:15 PM
ferby
19
Mar 23, 2005 09:10 PM
Fuster_Cluck
Mar 15, 2005 06:51 AM
B16OnTop
Jul 28, 2003 03:02 PM
