Fluidyne Teg rad in 2000 civic si???
I'm wondering, the full radiator that Fluidyne makes for 94-01 Integra, does in bolt on in my 2000 Civic si if I have removed the A/C?
Thanks
Thanks
Without modification to the brackets on the driver side where the a\c was before is what I'm trying to find out! Would prefer a full rad vs. a 1/2 rad!
Thanks
Thanks
I'm using a C&R Integra Radiator in my ITR swapped 96 Civic coupe. You will have to modify the driver side bracket. You'll have to remove the driver side bracket (drill out the spot welds) and screw it into the crossmember where it will need to be located. I'm pretty sure you'll have to remove the condenser brackets too. I had to make all new brackets for mine, but thats a whole other story.
JasinC19
Jun 2, 2012 04:58 PM
Hoodwinked
May 27, 2004 11:02 PM
battyx
Dec 9, 2003 03:37 PM
SoloSol
Oct 25, 2002 08:48 AM
