removing swirls ???
Old Jul 12, 2007 | 07:29 PM
98 ej8's Avatar
Default removing swirls ???
ever since ive owned my 98 coupe ive been battling with trying to get the damn swirls out of the paint...ive done everything and after i buff it the car will look great..no swirl marks..and after a few days of not washing the car or buffing it the swirls come back..any ideas on what i could do?
Old Jul 12, 2007 | 07:36 PM
johnxboi's Avatar
Default Re: removing swirls ??? (98 ej8)
what do you do when you buff it?
Old Jul 12, 2007 | 07:43 PM
98 ej8's Avatar
Default Re: removing swirls ??? (johnxboi)
random orbital buffer....buff it on then buff it off with a diff pad
Old Jul 12, 2007 | 08:12 PM
johnxboi's Avatar
hm. sounds like the scratches are pretty deep. try wetsanding the major areas with a fine grit sandpaper then using your orbital buffer to buff it out.
Old Jul 12, 2007 | 09:26 PM
EJ8tunerman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnxboi &raquo;</TD></TR><TR><TD CLASS="quote">hm. sounds like the scratches are pretty deep. try wetsanding the major areas with a fine grit sandpaper then using your orbital buffer to buff it out. </TD></TR></TABLE>
Instead, try and tell us what orbital buffer your using and what products your using and Myself or someone else such as Lastdetail or E-rok can lend you some advice.
Old Jul 13, 2007 | 01:13 AM
bobjohnson's Avatar
Man, i wouldnt recommend wetsand right away... Id probably say go to a higher cut compound first.
What color is the car? Im guessing its black... Try to get some Turtle Wax rubbing compound, then turtle wax polishing compound, then get some meguiars light cut finishing compound, the scratch-x stuff works really good (Someone on here recommended it to me).
Its going to take you a looonnngg time to do it, took me about 30 minutes to do a small section of my hood where a stray cat fell off. Dont rush it and itll turn out good.
Old Jul 13, 2007 | 03:37 AM
powerflow's Avatar
The deeper swirl marks/ light scratches need to be completely buffed out. Then follow that up with a high quality polish compound and a tool designed to polish. The machine buffing micro abrations need to be completely removed with the polishing step. Wet sanding should not be necessary, if the marks are not deep scratches. I use 3m final finish easy clean up polish, works really well.
Old Jul 13, 2007 | 09:24 AM
98 ej8's Avatar
Default Re: removing swirls ??? (powerflow)
the color of the car is dark green im using a random orbital buffer from craftsman and using swirl remover by a company called PRO...ICE polish and Fantastic finish wax also by PRO
Old Jul 13, 2007 | 02:01 PM
kiddcarbuff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerflow &raquo;</TD></TR><TR><TD CLASS="quote">The deeper swirl marks/ light scratches need to be completely buffed out. Then follow that up with a high quality polish compound and a tool designed to polish. The machine buffing micro abrations need to be completely removed with the polishing step. Wet sanding should not be necessary, if the marks are not deep scratches. I use 3m final finish easy clean up polish, works really well. </TD></TR></TABLE>make two of us.. i would also suggest the 3M along with a better buffer than a random orbital.
Old Jul 13, 2007 | 02:31 PM
powerflow's Avatar
Default Re: removing swirls ??? (kiddcarbuff)
Accually I don't use a rotary buffer to polish. I use a random orbit, dual action, high rpm polishing tool w/ the 3m polish.
Old Jul 14, 2007 | 02:26 AM
mztykal's Avatar
3m blows.
Old Jul 14, 2007 | 03:17 AM
brad.'s Avatar
Default Re: removing swirls ??? (mztykal)
It's funny how everyone recommends the most abrasive methods first.
Heany cut rubbing compound, wetsanding (which causes hazing and marring that cannot be removed by a $20 random orbital 12" buffer)
Sometimes the least agressive methods are all you need to remove the swirling....
Old Jul 14, 2007 | 12:09 PM
98 ej8's Avatar
just recently clayed/polished/waxed the car...so far no swirls lets see if this holds up and what did you use on those cars in the pictures????
Modified by 98 ej8 at 8:50 PM 7/14/2007
TallKyle
115
Jul 17, 2007 08:09 AM
924doorEG
Jul 8, 2007 04:04 PM
jbnny23
Apr 10, 2005 09:12 AM
SneezR
Apr 5, 2005 12:33 PM
I8Stang
Dec 16, 2004 07:10 PM
