do eg brake pads work for del sols?
well i got life time warrenty for eg brake pads at autozone and my 94 del sol needs to pads would the eg pads fit the del sol? please let me know thanks
http://www.autozone.com , check the part number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">what model civic, and what model del sol</TD></TR></TABLE>
its a si eg and the del sol is hmm has a dx motor in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvs2spooge »</TD></TR><TR><TD CLASS="quote">noone knows? off the bat?</TD></TR></TABLE>
Is it really that hard to enter the 2 cars at autozone.com and check the parts ?
If both cars have the same size front rotors, and the front calipers look the same, then yes they use the same Akebono calipers and pads. If the Civic Si is the super rare 94 ABS version, then the front brakes are larger and the pads will not fit the Sol...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">IF neither have ABS brakes they are the same, if BOTH have abs brakes they are the same, if one does and one doesnt they are differant.</TD></TR></TABLE>
That's not quite true...
<u>USDM market EG Civic hatchback & Del Sol front brake comparison:</u>
92-95 Civic Si/DX/CX/VX has small 9.4" front brakes with Akebono calipers
94 Civic Si ABS has large 10.2" front brakes with 17cl-14vn Nissin calipers
93-97 Del Sol S/Si has small 9.4" front brakes with Akebono calipers
94 Del Sol VTEC has large 10.2" front brakes with 16cl-14vn Nissin calipers
95-97 Del Sol VTEC ABS has large 10.2" front brakes with 17cl-14vn Nissin calipers
All three different calipers have their own brake pads...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">
thats very good info. it should be put into the FAQ somewhere.
</TD></TR></TABLE>thats very good info. it should be put into the FAQ somewhere.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvs2spooge »</TD></TR><TR><TD CLASS="quote">so the si's do fit on the del sol if i read it right..</TD></TR></TABLE>
It will unless the Si has ABS...
