CV Axle issue- HELP!!!
Old Jul 12, 2007 | 04:23 PM
itr590's Avatar
Default CV Axle issue- HELP!!!
Ok, guys, I need some serious advice concerning my car. I've gone through six axles in the past two months. Each one has displayed the same symptoms (passenger side/ transmission joints; continuous knocking). When I keep pressure on the shaft (i.e. accelerating, braking) the knocking is at a minimum. However, while cruising at steady rpms or coasting in neutral, the knocking noise is very noticeable. The first time, it got to the point where the tripod on the inner side of the shaft was toasted. I'm not putting monstrous amounts of power to the ground (MAYBE 190 whp), so I know it isn't a power issue. However, I leave for Virginia in two days. It's 2000 miles roundtrip and I am screwed if this happens on the road. Every shaft to this point has been a rebuilt one, each lasting around 100 miles until it goes out. The excessive repairs lead me to believe that something else is causing this continuous bs. From what I know about shafts (which isn't much), they basically go out on their own. Does ANYONE have an idea as to what it may be? Transmission, possibly? That would SUCK, but at least I could narrow it down. I just need to know what other causes there may possibly be (if any). These shafts are really becoming stressful. Of course, I'm in a bind now more than ever due to this trip. I need advice badly, fellas. Please help!!! Thanks!!!
Old Jul 12, 2007 | 04:42 PM
itr1244's Avatar
Default Re: CV Axle issue- HELP!!! (itr590)
check the other end where it splines with the axle.
check#17 and #18
http://www.sonsacuraparts.com/...Irno=
if your transmission shifts fine and have no grinds when you drive. it shouldn't be internal parts of the transmission.
6 axle in 2 months must be crazy
Old Jul 12, 2007 | 04:46 PM
itr590's Avatar
Default Re: CV Axle issue- HELP!!! (itr1244)
You have no idea. When you spend that much time fixing a problem and it keeps coming back, you start to wonder "What the @#$%!!!"
Old Jul 12, 2007 | 05:07 PM
itr1244's Avatar
yeah. for real.. but yeah check those 2 parts out .. look for visual damage.
it would help if you can post picture of the broken axle
Old Jul 12, 2007 | 06:08 PM
itr590's Avatar
bump for time!!
Old Jul 12, 2007 | 09:02 PM
ITR#132's Avatar
What do you have for suspension? Raise it up.
Old Jul 13, 2007 | 04:35 PM
itr590's Avatar
Default Re: (ITR#132)
stock
Old Jul 13, 2007 | 09:32 PM
Ill's Avatar
Ill
Default Re: (itr590)
What kind of rebuilt axles? A few years back, a couple of people reported some problems with low mileage failures on rebuilt axles, but I don't remember the brand.
Any chance you have suspension or other damage on the passenger side bearing/arm, that could be stressing the axle? How many miles on the caR? Seems like a toasted rear rubber trans mount (or mounts) might cause mis-alignment.
Only on the passenger side, and that's the only one you replaced?
LeeMajors19082
Oct 3, 2016 05:30 AM
1990whitecrx
Oct 31, 2010 12:04 PM
K i l l a B e e.
Sep 11, 2008 03:54 PM
jacoop86
Aug 11, 2006 04:07 PM
dubbedcorde
10
Jan 6, 2005 04:16 AM
