Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
sub and amp install question(07 SI)
Old Jul 12, 2007 | 03:30 PM
slowsupra's Avatar
Default sub and amp install question(07 SI)
ok, i've search and i'm not coming up with anything even though i know i've seen info on this here..... i'm in dummy mode today and am not using the proper search tems to get me an answer..lol..
07 si sedan, no navi, looking to put a amp and sub in it and still be able to use the factory head units sub control..can it be done/how can it be done/what do i need..ect/ect..
somebody help me out, i'm getting sick of my girl telling me she has no bass and wants her amp/sub from her last car installed in this damn car...lol
thanks, jay
Old Jul 12, 2007 | 04:06 PM
EJ8VTECFTW's Avatar
Default Re: sub and amp install question(07 SI) (slowsupra)
well u could run a split from your stock subwoofer..
and the stock sub has good bass for being stock..
otherwise id be to lazy to have to take my dash out just to install more subs, it just takes up more weight in the trunk neways
Old Jul 12, 2007 | 04:31 PM
JTaudio0212's Avatar
Default Re: sub and amp install question(07 SI) (EJ8VTECFTW)
Use a line level converter... you can get one at best buy or circuit city for around 25$... and when you use the line level just tap off the factory sub wires for the signal and run RCA's from there, that way you can adjust the input level to the amp by controlling the sub off of the stock headunit.
and as far as the rest of the install goes... it kind of sucks good luck
Old Jul 12, 2007 | 05:54 PM
slowsupra's Avatar
Default Re: sub and amp install question(07 SI) (JTaudio0212)
i wase'nt sure if i could tap off the subs wires for the line level converter.. i have one from the last car i put this **** in for her..lol.. i'll have to find it and get it done so she'll stop going on about it..
thanks.
Old Jul 12, 2007 | 06:02 PM
Bulli Kid's Avatar
i want to to this o my lx. sound system blows stock.
what you need to do i either get an amp with speaker level imputs , which is basically a line out converter built in and tap in the stock speaker wire. that will give you sound. you dont need rca cables if you have it built in. just regular speaker cables. guessing 14-18 gauge should do. if you go with the LOC you will need rca cables and just connect them. What also is needed is a remote wire, which powers up the amp when the key is turned or deck turned on. other wise the amp will work all the time which = that about it.
Old Jul 12, 2007 | 06:10 PM
EJ8VTECFTW's Avatar
Default Re: sub and amp install question(07 SI) (Bulli Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulli Kid &raquo;</TD></TR><TR><TD CLASS="quote">i want to to this o my lx. sound system blows stock.
what you need to do i either get an amp with speaker level imputs , which is basically a line out converter built in and tap in the stock speaker wire. that will give you sound. you dont need rca cables if you have it built in. just regular speaker cables. guessing 14-18 gauge should do. if you go with the LOC you will need rca cables and just connect them. What also is needed is a remote wire, which powers up the amp when the key is turned or deck turned on. other wise the amp will work all the time which = that about it. </TD></TR></TABLE>
sorry i was talking about the premium sound system on the ex's and si's..
otherwise yea they do suck..
Old Jul 12, 2007 | 07:08 PM
Bulli Kid's Avatar
yes i know what you were talking about i was just saying i am wanting to put a amp and sub in a lx. terrible speakers. should have bought an ex : (
Old Jul 12, 2007 | 09:33 PM
the firewall on the new civics are rough as well, i can almost fit my arm up to my elbow inbetween the air filter and the top of the block and barely touch the firewall.. but to get a power line through just gently cut the rubber boot thats upper right to the gas pedal and remove the air filter top under the hood and you should be able to stick your hand back to the firewall (the boot is almost directly behind the airfilter maybe a little to the left) and push the wire through, and spray some windex on the wire, it helps lube for about 30 seconds then dries to a really sticky state so it will seal itself in the boot properly...
Old Jul 12, 2007 | 09:36 PM
and also the good side of using a line level vs. a direct high level input from an amp, you get cleaner sound putting low end signal straight into the RCA inputs...
although it is usually personal preference, but whatev.
Old Jul 13, 2007 | 01:13 PM
EJ8VTECFTW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTaudio0212 &raquo;</TD></TR><TR><TD CLASS="quote">and also the good side of using a line level vs. a direct high level input from an amp, you get cleaner sound putting low end signal straight into the RCA inputs...
although it is usually personal preference, but whatev.</TD></TR></TABLE>
nice point out
Old Jul 13, 2007 | 03:03 PM
hondamanforlife's Avatar
yea what JTaudio said! put the wire in thru the boot and run it down the driver side . its easy just pull the panels and rum the wire. I used a line level converter and it worked great for a wial , but my converter burned up not sure if the factory amp sent to much power thru the converter or it just shorted out . I got a new one and im going to try again. I am running a mono alpine amp to a single alpine S 12' and it sounds great with the factory radio and speaker . well ballanced sound thats not overpowering the stock system. besides I like to try to keep the wieght down.
Old Jul 13, 2007 | 06:05 PM
Default Re: sub and amp install question(07 SI) (hondamanforlife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanforlife &raquo;</TD></TR><TR><TD CLASS="quote">yea what JTaudio said! put the wire in thru the boot and run it down the driver side . its easy just pull the panels and rum the wire. I used a line level converter and it worked great for a wial , but my converter burned up not sure if the factory amp sent to much power thru the converter or it just shorted out . I got a new one and im going to try again. I am running a mono alpine amp to a single alpine S 12' and it sounds great with the factory radio and speaker . well ballanced sound thats not overpowering the stock system. besides I like to try to keep the wieght down. </TD></TR></TABLE>
Very nice set-up.
and also, if your gain is turned up too high on your amp, it can cause a line level to go bad because it tries to draw too much current off of the factory signal through the line level and will usually cause the line output converter to go bad... not to mention cause a lot of distortion in your sub.
Old Jul 13, 2007 | 06:55 PM
redciv's Avatar
...disconnect your factory sub if using aftermarket..just unplug.
Old Jul 13, 2007 | 07:32 PM
Default Re: (redciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redciv &raquo;</TD></TR><TR><TD CLASS="quote">...disconnect your factory sub if using aftermarket..just unplug.</TD></TR></TABLE>
Thats actually a very good point (if you remove the sub and put the grill back on it will actually make your subs louder and clearer because the hole will act as a small port thats directly inside your car)... and also I tried to put an infinity reference 8" in the factory subs place, and it sounded like crap $hit because not very many subs can actually run "free air"
but if anyone wants an infinity 8" reference series sub let me know
Old Jul 14, 2007 | 06:56 PM
Default Re: (JTaudio0212)
I deleted the factory sub but left it in place. thanks for the input on the gain. I do keep the gains down so I have more control thru the head unit
cmasonrun
Sep 21, 2011 06:47 PM
Sorcin
Audio / Security / Video
May 17, 2010 09:07 PM
tienzien
Sep 25, 2008 04:25 AM
elitetuning
Dec 13, 2005 09:52 AM
XViEtBoiX
Jan 21, 2004 05:36 PM
